<<  1    2  >>
New Topic New Reply
Author: Subject: Lockwire
mikeb
posted on 26/2/18 at 02:08 PM Reply With Quote
Lockwire
I need to lockwire my brake adjuster for IVA.
I don't have the lockwire pliers tool (or any lockwire)
Is there a locost way, seems a waste to buy one for 1 job.
Mike
ttalps2000
posted on 26/2/18 at 02:17 PM Reply With Quote
Drill and pin it with a nut on the end is the most common way. Mine was not inspected on IVA and they took my word for it. They were more concerned with the sticker that needs to be put by the bias bar!
joneh
posted on 26/2/18 at 02:18 PM Reply With Quote
Split pin?
Don't forget the warning sticker now required...
Charlie_Zetec
posted on 26/2/18 at 02:24 PM Reply With Quote
Castle nut and split pin do the job?
JeffHs
posted on 26/2/18 at 03:49 PM Reply With Quote
Ordinary pliers work just as well for occasional use. Cut the wire long, start the twist by hand then finish off with the pliers. Cut to length then tuck the end away so it doesn't snag on your hands next time.
mikeb
posted on 26/2/18 at 03:50 PM Reply With Quote
sounds good castle nut and split pin.
Thanks for the note about the sticker. does it need to be in the footwell or on top of the panel that I remove to access the pedal box from above?
pewe
posted on 26/2/18 at 03:53 PM Reply With Quote
Wire it up, grasp the two ends in a small battery drill chuck, turn until it shears - simples.
Cheers, Pewe10
joneh
posted on 26/2/18 at 04:05 PM Reply With Quote
I thought it was supposed to be by the master cylinders and that's where I was going to stick it but by the bias bar would make more sense but would be out of sight...
ttalps2000
posted on 26/2/18 at 04:20 PM Reply With Quote
mine is on top of the access panel, as you would have to remove the panel to adjust the bar. The IVA guy said it could also go by the bias bar.
He told me to get x2 of them, put one on the access panel and bring a spare in case he was not happy with it and then stick it where he wants on the re-test!
CBS do them and are less than a quid each from memory.
Remember to do the brake fluid stickers too!
Schrodinger
posted on 27/2/18 at 08:41 AM Reply With Quote
I didn't lock mine I just had a sticker bough t from CBS https://www.carbuildersolutions.com/uk/iva-brake-bias-sticker-balance
this was accepted by Norwich.
Keith
Aviemore
gttztt
posted on 27/2/18 at 09:05 AM Reply With Quote
Wirelocking
Cheapest way - by hand. 14 twists per inch and if you are an aircraft engineer do it in the dark using a torch looking into a mirror upside down with hydraulic oil dripping down your sleeve breathing in AVTUR - or not.
Daf
posted on 27/2/18 at 09:19 AM Reply With Quote
Make a big loop and tie the two ends together, put a hoak 8n the chuck of your drill and hook onto the loop. Spin away until it looks nice then chop off the excess
tims31
posted on 1/3/18 at 11:26 AM Reply With Quote
Been there, done that....
Build: http://www.martinsfurybuild.co.uk/
posted on 1/3/18 at 12:44 PM Reply With Quote
Had to google AVTUR...
It's aviation jet fuel, to save anyone else from looking.
tims31
posted on 1/3/18 at 01:56 PM Reply With Quote
Stands for 'Aviation Turbine' AV TUR
Also AV GAS - Aviation Gasoline and AV PIN which is a monofuel used to start the older RR Avon engines, nasty stuff which once burning only stopped once the fuel had been exhausted and the by product left behind was Arsenic!!! Wiki
[Edited on 1/3/18 by tims31]
Daf
posted on 1/3/18 at 02:33 PM Reply With Quote
Just finished reading a book on the English Electric Lightning and learned about AV PIN, mentioned in there that it was a little bit nasty! Lightning was a spectacular bit of engineering for it's day though. Surely leaking AVTUR would be an IVA fail?
[Edited on 1/3/18 by Daf]
Schrodinger
posted on 1/3/18 at 02:59 PM Reply With Quote
there is an Aviation Museum just round the corner from me with among other things a Lightning on display. There are also a couple of merlin engines there as well, something I hadn't realised until recently was that only about half of them were made by RR, the others were made by Ford (in the UK)and GM (in the USA).As they came in to RR for servicing they removed any reference to any other manufacturer.
[Edited on 1/3/18 by Schrodinger]
Keith
Aviemore
tims31
posted on 1/3/18 at 03:34 PM Reply With Quote
For IVA yes but on an aircraft if it isnt leaking then it must be empty, when it stops leaking you worry...
posted on 1/3/18 at 03:52 PM Reply With Quote
One of my neighbours used to be the USAF deputy fire chief at RAF Bentwaters - he told me about the SR-71, and how it leaked fuel constantly until the skin heated up at flying speed. The fuel was so safe that you could stick a burning torch into it and it wouldn't light. When he did training exercises they had to pour a couple of gallons of petrol over the jet fuel and light that to get the whole lot going. Mind you, when the jet fuel did eventually ignite...
slingshot2000
posted on 2/3/18 at 12:00 AM Reply With Quote
Sorry to jump on this thread, but could you please name the above mentioned book??
Daf
posted on 2/3/18 at 08:46 AM Reply With Quote
Actually since Christmas I've read 3 books on it! The Lightning Boys 1, The Lightning Boys 2 (borh by Richard Pike) and Fighter Test Pilot by Roland Beamont - the lighting test pilot.
I have a fascination with cold war technology, the lightning in particular as seeing one fly over is one of my earliest memories - I was 3 at the time and it has stuck with me!
tims31
posted on 2/3/18 at 02:32 PM Reply With Quote
Yep that's right but the fuel was of jelly like consistency. The SR-71 was made of Titanium as it was the only material at the time that could cope with the heat generated flying at Mach 3. There is a good documentary on Youtube about it
[Edited on 2/3/18 by tims31]
scudderfish
posted on 2/3/18 at 06:05 PM Reply With Quote
This is an excellent book about the development of liquid fuels for rockets.
https://library.sciencemadness.org/library/books/ignition.pdf
johnH20
posted on 4/3/18 at 07:39 PM Reply With Quote
It is amazing that the video is now in the public domain. Only three years ago I was invited to an ImechE talk by one of the pilots and entrance was still restricted at that time. Great viewing thanks for posting.
coyoteboy
posted on 5/3/18 at 01:03 PM Reply With Quote
Aviation fuel has lower energy density and higher flash point than petrol - petrol is an entirely more unpleasant and dangerous fuel.
<<  1    2  >>
New Topic New Reply
