Author: Subject: How do you clean yours?
chrisbmxr
posted on 2/3/18 at 04:27 PM Reply With Quote
As my MK Indy is my first experience with GRP panels, I'm just wondering whether there is any special advice or any products to avoid when cleaning?
There are quite a few swirl marks in the gel coat. Is it ok to buff these out as you would a painted finish, or am I going to rub through the gel coat?
Thanks!
CosKev3
posted on 2/3/18 at 04:38 PM Reply With Quote
Never done it myself but have seen people Polish them up as you say,same as a painted car
posted on 2/3/18 at 04:41 PM Reply With Quote
My GRP bodied MK Indy a few years back was simply washed with a good car shampoo and a soft mit type thing. I then used a chamois to dry it and turtle wax to polish it. It came up looking nice and shiny and I never had any issues with the gel coat.
Yellow body panels with black wings.
russbost
posted on 2/3/18 at 06:06 PM Reply With Quote
GRP is immensely hard, much harder than paint, it's only real faults are that it can chip & star.
You can rub it over with much coarser compounds than you would paint with no chance of rubbing thro' (unless the gel is already so thin it would be transparent in the first place), the downside is that because it's much harder it takes a lot more buffing to get it up to a real deep gloss shine than paint does, I always use a power mop on it for that reason
ReMan
posted on 2/3/18 at 08:23 PM Reply With Quote
I'm one of the drive it brigade , not a polisher
So I just jetwash , shampoo, jetwash drive it round the block to dry it and then a quick rub over with the spray polish if its a special occasion
What are swirl marks
No reason not to buff and wax like any other
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
SJ
posted on 2/3/18 at 09:21 PM Reply With Quote
Mine tends to stay mucky.
HappyFather
posted on 2/3/18 at 10:49 PM Reply With Quote
I just rub mine with a cloth where I poured some petrol. Takes rubber and bugs off pretty well. Whatever didn't come off and the scratches is just "character".
Mr Whippy
posted on 3/3/18 at 08:14 PM Reply With Quote
Don't use thinners...
Don't go crazy as gel coated is uneven and sometimes quite thin, break through it and you hit the weave. Gel coat cos it's hand applied often has bubbles which you may uncover but these can be filled with matching wax crayon and buffed. Once done protect it from UV with a good polish as gel coat oxidises usually worse than paint. No matter what you do it's never going to match a paint job though so don't expect too much.
ragindave
posted on 4/3/18 at 02:28 PM Reply With Quote
G3 compound works well use with water.
Can be applied by hand or electric mop.
https://www.ebay.co.uk/i/221367045342?chn=ps&adgroupid=54713418609&rlsatarget=pla-411723801350&abcId=1133926&adtype=pla&merchantid =113547458&poi=&googleloc=9046220&device=c&campaignid=1057752920&crdt=0
bonzoronnie
posted on 4/3/18 at 02:49 PM Reply With Quote
+ 1 for G3
We use this a lot on our GRP boats
Will cut out fine swirl marks, light stains & will buff up to a good gloss.
Plenty of water is the key.
ETA
I use sponge waffle pads for small areas that need to be done by hand.
[Edited on 4/3/18 by bonzoronnie]
