Author: Subject: New tool acquired
posted on 5/3/18 at 03:20 PM Reply With Quote
New tool acquired
Need to drop the engine oil out of my Peugeot 205 GTI. The sump plug takes a square drive so I looked about for a suitable socket for the job. They're available, but seem to start at around £5 a piece.
Then I recalled in my younger days taking the 8mm x 8mm square spindle out of my bedroom door for the job. Found one on ebay for £1.50 + £0.00 shipping. Problem solved...
slingshot2000
posted on 5/3/18 at 03:38 PM Reply With Quote
Why didn't you just "borrow" one from a bedroom door, not necessarily your own room?
Good lateral thinking, by the way !
loggyboy
posted on 5/3/18 at 04:12 PM Reply With Quote
I bought a Laser version of this https://www.ebay.co.uk/itm/5-Pce-Sump-Plug-Key-Set-Car-Axle-Sump-Oil-Draining-Tool-Socket-Set/183031657912
for ~£15 10+ years ago which has paid for itself several times over. Its done every oil plug, and more random things like the cam pulley on the clio.
Mistral Motorsport
posted on 5/3/18 at 04:15 PM Reply With Quote
Don't live in my parents house any more and I suspect they'd get the arse if I pilfered a door part
posted on 5/3/18 at 04:16 PM Reply With Quote
Didn't come across that set, but it does look good and I'd probably have bought it as well.
posted on 6/3/18 at 09:27 AM Reply With Quote
I'm seeing the issue now...it doesn't appear to have an 8 mm x 8 mm square, which is the one I need for the 205 GTI sump plug
loggyboy
posted on 6/3/18 at 09:38 AM Reply With Quote
Sizes included in this set: (3/8" & 11mm Square), (8mm & 13mm Square), (9mm & 5/16" Hex), (10mm & 12mm Hex), (14 & 17mm Hex).
Mistral Motorsport
posted on 6/3/18 at 10:37 AM Reply With Quote
OK - I didn't read it properly
That would do the task at hand!
Mr Whippy
posted on 6/3/18 at 12:10 PM Reply With Quote
I find most socket drives fit the plugs, my Landy uses 1/2 inch
posted on 6/3/18 at 03:56 PM Reply With Quote
They may on some, but I've got 1/4, 3/8 and 1/2" sockets so no good for this on I'm afraid.
