Author: Subject: Worcester Bosch Boiler Leak
SJ
posted on 5/3/18 at 08:23 PM Reply With Quote
Anyone know if there are common issues with a WB 30CDI boilers leaking? Ours is only about 4 years old but just discovered it has clearly been leaking for ages inside, but only enough to drip out a little bit externally. Looks a right rusty mess inside though.
Stu
907
posted on 5/3/18 at 08:39 PM Reply With Quote
Weld it up.
It's like putting a new sill on a car.... but soooo much easier.
My local plumber often drops one off to me. It's become a nice little earner.
Paul G
Member of the Suttol Owners Club, the MX5 Owners Club and the BMMC
SJ
posted on 5/3/18 at 08:46 PM Reply With Quote
"Weld it up.
It's like putting a new sill on a car.... but soooo much easier."
Do I need to turn the gas off first?
[Edited on 5/3/18 by SJ]
v8kid
posted on 5/3/18 at 09:16 PM Reply With Quote
At 4 years old its still under guarantee - Bosch service is second to none on the domestic heating market - contact them
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   v8kid 's Aim
SJ
posted on 5/3/18 at 09:19 PM Reply With Quote
I did check on the paperwork but according to the warranty card the standard warranty is 1 year, with 2 if you register when purchased.
What makes you think it is still under guarantee?
adam1985
posted on 5/3/18 at 10:17 PM Reply With Quote
Could be a number of things, left, right hydroblocks and flow-sensors are know to leak or could be related to the condensate pipework. With you not saying anything about adding water to the system makes me think its one of the above.
Thankfully worcester parts seem to be reasonable.
Weld it up! Everybody knows worcesters are plastic
v8kid
posted on 5/3/18 at 10:38 PM Reply With Quote
Mine has a 5 year guarantee standard. The service technician mucked up the second service and forgot to replace the gas sampling plug consequently the corrosive gasses dissolved the internal wiring. Fortunately for my health it was in an external plant room😀
Bosch replaced it with the latest boiler including all labour at no cost and reset the guarantee with another 5 years
That's what makes me think it's under guarantee.
Charlie C
posted on 6/3/18 at 07:13 AM Reply With Quote
Give Worcester Bosch customer services a call they will tell you the warrenty length, its worth a 5 min call could save you hundreds.
When we had our worcester boiler installed 5 years ago it came with 5 years warrenty as standard with another 2 years if it was fitted by an approved inataller. I think their standard warrenty is 7 years now.
SJ
posted on 6/3/18 at 07:41 AM Reply With Quote
Apologies - I found the other paperwork with the boiler and the warranty is 5 years. I'll be calling them this morning.
Adam1985 - No, I haven't added any water and it still works fine so could be to do with the condensate pipework.
Stu
cliftyhanger
posted on 6/3/18 at 09:22 AM Reply With Quote
B#%*y hell, a "technician", with all his special certificates and training, and deemed competent, did that!!!
He could have been done for negligent manslaughter.......
I really do not trust many tradesmen at all. They are generally lazy and far from competent. Good ones are worth hanging on to.....
(sorry for drift)
edit for spelling!
[Edited on 6/3/18 by cliftyhanger]
SJ
posted on 6/3/18 at 09:36 AM Reply With Quote
(sorry for drift)
edit for spelling!
I have a nagging feeling that our boiler was fine until it was serviced around a year ago. The day it was serviced there were a couple of drips of water came out, but no more seemed to come out after we had dried it up and the gas firm who serviced it claimed all was fine.
The Worcester Bosch guy is coming today so lets see. No covered by warranty though as the last service was more than 12 months ago.
Stu
[Edited on 6/3/18 by SJ]
v8kid
posted on 6/3/18 at 12:08 PM Reply With Quote
Stu,
If only a few months out they should look favourably on it IIRC mine had a patchy service history but they were OK. As I said their customer service is excellent.
Push a little bit for UG repair.
SJ
posted on 6/3/18 at 12:24 PM Reply With Quote
Stu,
Thanks for the tip.
They've been now and fixed it and you are right, the service was good. In fairness they charged to repair it but it was only about 90 more than a service would have cost anyway so not complaining.
They reckon it was caused by the flue O ring not being put in properly when new.
Stu
coyoteboy
posted on 6/3/18 at 09:05 PM Reply With Quote
I believe the commonest fault is the bleed valve leaking, which is easy to find/fix.
Ours was fine for 10 years without even a service, though last year it started not igniting - replaced the ignitor tips and cleaned out the combustion chamber - been flawless and silent since.
Report your local potholes, it actually works!
YOUSAY54
posted on 7/3/18 at 01:30 PM Reply With Quote
worcester bosch boiler leak
We had a Worcester bosch boiler fitted last march by a company in chesterfield begins with A if we use them for service 10 year guarantee few problems but brilliant boiler.
