matty h
posted on 10/3/18 at 08:22 PM |
Mini tilting lift
Looking the mini tilting car lifts like this one.
https://www.ebay.co.uk/itm/MOBILE-SCISSOR-LIFT-TILTING-CAR-LIFT-RAMP-ADJUSTABLE-WIDTH-1500Kg-Capacity/253473094036?hash=item3b042c7994:g:9KwAAOSwcUBYL
vBi
Anyone have any experience of them or recommendations as to where to buy from.
Matty
[Edited on 10/3/18 by matty h]
froggy
posted on 10/3/18 at 09:13 PM |
I have one but had to cut it up to fit both my cars having space frames roughly 1100mm wide . Built both cars using the lift to get the car high
enough to work around and under plus it doesn’t take up much room when it’s not needed
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
40inches
posted on 11/3/18 at 12:34 AM |
I got one the end of last year. The adjustable width is a godsend
I got the same one as in your link. Some a bit cheaper from Germany, but I settled for that one.
[Edited on 11-3-18 by 40inches]
posted on 11/3/18 at 01:42 PM |
A trolley jack and 4 axle stands have always done for me.
Looking at the one in your link I guess it could be stood on end and lent against a wall when out of use.
cliftyhanger
posted on 11/3/18 at 06:31 PM |
I have used CJ Auto's axle stands on wheels thingies, and they were really well made. May be worth having a look at what they offer?
Madinventions
posted on 12/3/18 at 11:28 PM |
This is one of the German equivalents off eBay lifting my MG ZS track car way up into the air ready for a rear suspension rebuild (and yes, I did put
axle stands under it before I went much closer!) and wouldn't be without it now. You need quite a bit of space to the side of the car to slide
it under but it's very stable and easy to use. The only modifications I did were to narrow it down by around 250mm as it was far too wide for
any of my cars in it's standard "minimum" position, and bought a cheap SDS drill to do the heavy lifting because the hand crank was
just far too slow and laborious.
  MG tilting lift
Ed.
View my band website:
http://www.shadowlight.org.uk
matty h
posted on 13/3/18 at 01:38 PM |
Thanks for the replies going to bite the bullet and get myself one was looking at the mobile scissor lifts at £1200 but think I will use this more as
more mobile and less than half the price. Do you have a link to the German one on e bay to compare.
Matty
COREdevelopments
posted on 13/3/18 at 04:21 PM |
I too am interested in purchasing a tilt lift. Possible group buy?
Rob
matty h
posted on 13/3/18 at 04:38 PM |
I am up for a group buy if we can get more intrested my prefered choice at the moment is the one in my link mainly because my brother can collect it
from there as just down the road from him.
Matty
COREdevelopments
posted on 13/3/18 at 04:42 PM |
Well I am definitely up for it, especially if a good discount is on offer.
Madinventions
posted on 13/3/18 at 04:46 PM |
This is the link I got mine from back in September 2015 (oskar-design) but it looks like they don't currently have any. There are many similar
ones on the market and there also seem to be quite a few 2nd hand ones popping up on Gumtree, Facebook Marketplace and similar sites?
<<<eBay
link>>>
Ed.
[Edited on 13/3/18 by Madinventions]
