Author: Subject: Pre IVA Pictures - Haynes Roadster
mikeb
posted on 11/3/18 at 03:00 PM Reply With Quote
Would welcome feedback on IVA fails, I have about 3 weeks to go.
IMG_0593[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
IMG_059 2 by mjb22001, on Flickr
IMG_0590[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
IMG_0589[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
IMG_0587[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
IMG_0586[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
IMG_0584[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
IMG_0583[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
IMG_058 2 by mjb22001, on Flickr
IMG_058 1 by mjb22001, on Flickr
IMG_0577[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
mikeb
posted on 11/3/18 at 03:02 PM Reply With Quote
Things already on the list:
1. Under-dash panel that holds relays (already made)
2. Steering wheel, I have an old sierra one somewhere
3. Handbrake surround trim (not sure how to radius this!)
CosKev3
posted on 11/3/18 at 04:30 PM Reply With Quote
Looks good
Nut covers on the bolts going threw the top of the hub if the sphere can fit in there,
And are the front indicators far enough out?
CosKev3
posted on 11/3/18 at 04:39 PM Reply With Quote
Oh and have you locked off the brake bias bar?
mackei23b
posted on 11/3/18 at 05:59 PM Reply With Quote
The lower dash edge deeds to be 19mm radius, unless it is padded.
Ian
Davedew
posted on 11/3/18 at 06:24 PM Reply With Quote
Nut covers on roll bar mountings behind seats.
Lock nut on top link of front suspension needs covering.
Front indicators definitely look to far in.
Nice build, be good to see another one on the road
[Edited on 11/3/18 by Davedew]
gremlin1234
posted on 11/3/18 at 07:22 PM Reply With Quote
do the rear lights have reflectors built in
or do you need to add some
does look nice
CosKev3
posted on 11/3/18 at 07:36 PM Reply With Quote
does look nice
Well spotted,yeah needs reflectors as those lights haven't got them built in
mikeb
posted on 11/3/18 at 07:47 PM Reply With Quote
I think I bought reflectors they must be in th tool box.
Bias bar and stickers. Indicators are so close to 400mm but r boarder line
[Edited on 11/3/18 by mikeb]
CosKev3
posted on 11/3/18 at 08:02 PM Reply With Quote
It will fail on them if they don't meet the requirements
Davedew
posted on 11/3/18 at 09:17 PM Reply With Quote
Can’t tell from the pics, but have you got the offset mushroom inserts in the uprights with the hole nearest the front?
Needed to increase caster angle and help with self entering.
MikeR
posted on 12/3/18 at 09:47 AM Reply With Quote
The bolt on the exhaust clamp - can it be reached by a radius tester?
Otherwise looks good.
mikeb
posted on 12/3/18 at 10:37 AM Reply With Quote
I'll spin the inserts round, the whole if facing towards the back. Did it make much difference to self centering
zx12r dug
posted on 12/3/18 at 10:42 AM Reply With Quote
Hi nice looking car.bottom of the shocks I would cover.Around the exhaust hole maybe some trim.Not many people have passed with dominator headlights.The metal trims that you step over to get in are they radias enough.on my builds I needed to put some type of padding under the handbrake cover as it feels sharpe if lent on.Is the fuel cap tethered and has the nozzle restrictor inside.Nosecone indicators are measured from the widest part of the body my testers put a long bar on the floor only then I realised he was measuring from the width of the rear where as I measured to the edge of the front arch.Any pics of the engine bay we can look at.Not nit picking mate just best be safe than sorry.Ive gone through 5 tests and all testers have different views on what's right all's you can do is prepare the best you can get your fail sheet if you get one and crack on.Good luck
Daf
posted on 12/3/18 at 11:30 AM Reply With Quote
Has Your fog light got the correct marking on it?
mikeb
posted on 12/3/18 at 07:35 PM Reply With Quote
Fog light has a E mark on it, i think that is all it needs.
Fuel filler doesn't need to be tethered if it is lockable with a key... i think!
IMG_0598[ /url] by [url=https://www.flickr.com/photos/62740914@N04/]mjb22001, on Flickr
kingster996
posted on 12/3/18 at 07:37 PM Reply With Quote
Looks good.
Remember that indicators are 400mm from widest part of car which will be the rear arches.
Edit - looks like that was spotted by zx12r dug too
[Edited on 12/3/18 by kingster996]
I used to be indecisive, but now I'm not so sure
CosKev3
posted on 12/3/18 at 07:43 PM Reply With Quote
That's only the case if the key can't be removed from the filler cap once it's off the car?
If the key will come out of the cap when the cap is open it needs to be tethered
mikeb
posted on 13/3/18 at 01:22 PM Reply With Quote
You might be right with regard the fuel filler tethering, not sure how to do it other than drilling a whole in the T bit of cap and tethering to one of the mounting bolts
loggyboy
posted on 13/3/18 at 01:33 PM Reply With Quote
Needs to have a F or B marking also.
Also check its dead straight to rear, both left/right and up/down
[Edited on 13-3-18 by loggyboy]
Mistral Motorsport
CosKev3
posted on 13/3/18 at 01:48 PM Reply With Quote
Has it got a nut/bolt on the end internally?
Most I've seen use a chain connected to the end of the cap with a big washer or summat in the filler neck that won't fit out
tims31
posted on 13/3/18 at 05:47 PM Reply With Quote
Not sure what the inner part of your cap is like but I attached a piece of brass cable to the cap with a loop crimp attached to a bolt on the cap and then attached the brass cable to a loop of wire dropped into the tank that stops it being pulled out. Also easy to fit and remove if you want to after.
Also, how much movement does the handbrake have as it looks quite high?
Build: http://www.martinsfurybuild.co.uk/
chris_smith
posted on 13/3/18 at 10:55 PM Reply With Quote
Have you got a warning label for the brake fluid? Have you got chassis stamped and separate vin plate, couldn’t see in engine pics?
mikeb
posted on 14/3/18 at 06:30 AM Reply With Quote
Still need to make the manufacturers plate. Brake fluid res has sticker. Thanks
mikeb
posted on 14/3/18 at 06:33 AM Reply With Quote
I have a rad fan switch on the dash that doesn’t say what it is. Will this need a label?
