Author: Subject: Mmr vortex handbrake switch
MnrvortexR1
posted on 13/3/18 at 03:19 PM Reply With Quote
Hi I'm currently building the above mentioned kit car and I've drawn a blank on where to correctly mount the handbrake switch supplied with the kit if anyone has any info it would be greatly appreciated TIA
[Edited on 13/3/18 by MnrvortexR1]
loggyboy
posted on 13/3/18 at 04:32 PM Reply With Quote
As in the switch that triggers the warning light?
Anywhere that make the switch come on when the hand brake is pulled.
Mistral Motorsport
MnrvortexR1
posted on 13/3/18 at 04:47 PM Reply With Quote
Ok mate cheers I'd thought as much there just isn't any info on the mounting of the switch to the chassis and the switch to the handbrake itself I've got the hand brake installed and set up so the next step is to attach the switch I'll have a tinker with it tomorrow and see if I can figure it out.
posted on 13/3/18 at 05:03 PM Reply With Quote
Some time back, but I used a Sierra handbrake lever on my MK Indy. From memory the switch was already attached to the Sierra handbrake, it simply switched when you lifted the handbrake lever.
loggyboy
posted on 13/3/18 at 05:17 PM Reply With Quote
Post some pictures up of what you have (brake, switch and chassis area).
Mistral Motorsport
MnrvortexR1
posted on 13/3/18 at 06:01 PM Reply With Quote
I might be being stupid here but it won't let me attach photos ? Says it needs a website but they are on my phone?
loggyboy
posted on 14/3/18 at 08:38 AM Reply With Quote
You should be able to upload them here http://locostbuilders.co.uk/photos.php - however as modern phone pics are quite hi res you might need to resize them, (most phones have a built in app for this, or you can down load one)
Mistral Motorsport
MnrvortexR1
posted on 14/3/18 at 08:44 AM Reply With Quote
Yeah I've uploaded 3 photos, two of the installed handbrake and one of the switch.
posted on 14/3/18 at 09:02 AM Reply With Quote
Best to re-size photos before you upload them (I usually re-size to 800 pixels wide). If you then look at the uploaded photo this forum then gives you link text to copy and paste into your post to include the photo in your post.
