Author: Subject: Electrical gremlins related to ignition light
petroldiaries
posted on 19/3/18 at 06:52 PM Reply With Quote
I hit some electrical gremlins in Episode 7 of my Westfield restore diary (See link below). I'm fitting replacement LED dash lights as the old ones have seen better days, also I'm fitting new switches as these have started to discolour and are showing signs of corrosion on the back. I've been contacted by someone whose recommend I check the ignition switch as he's seen similar engine running down issues when jiggling the wires, anyone else seen similar?
https://youtu.be/B12DvmgrSSs
If anyone can make use of a full set of old switches let me know, free to anyone who wants on here.
petroldiaries
posted on 19/3/18 at 07:00 PM Reply With Quote
It probably helps if I post a picture;o)
CosKev3
posted on 19/3/18 at 07:03 PM Reply With Quote
Just be aware you will need to do some extra fiddling about with the wiring if you intend to use a LED instead of a filament bulb for the ignition light
petroldiaries
posted on 19/3/18 at 07:07 PM Reply With Quote
Erm ok I just assumed i could do a like for like swap, is there more to it?
daviep
posted on 19/3/18 at 07:36 PM Reply With Quote
Charging circuit may not work with LED installed instead of filament bulb, LED may not draw enough current through the alternator excitation circuit to start charging process. You can install an additional hidden bulb or resistor to make it work properly.
A truly great library contains something in it to offend everyone.
big_wasa
posted on 19/3/18 at 07:49 PM Reply With Quote
You could treat your self to a bright 6 display.
starterman
posted on 19/3/18 at 08:08 PM Reply With Quote
Daviep is right in what he says about an LED ignition light not working. Put a resistor in the line and it will be ok.
Mike
petroldiaries
posted on 19/3/18 at 08:58 PM Reply With Quote
Wow thanks for the great advice guys, glad I posted on here otherwise could have been chasing my tail again.
CosKev3
posted on 19/3/18 at 09:19 PM Reply With Quote
Yeah as above ref exitation,your new alternator would not be charging with just a LED warning light
gremlin1234
posted on 19/3/18 at 09:34 PM Reply With Quote
Mike
the resister should be in parallel not series (I am sure you know that, but to make it explicit for others ;-)
other thing to note, led's are 'directional' ie have pos and neg, filament bulbs don't care
edit sp
[Edited on 19/3/18 by gremlin1234]
petroldiaries
posted on 19/3/18 at 09:35 PM Reply With Quote
Cheers mate!!! I like the hidden bulb idea
daviep
posted on 21/3/18 at 07:37 PM Reply With Quote
Mike
TBH I have never given it any thought, what's the reason it must be in parallel? Off the top of my head I can't think why it makes any difference.
Davie
starterman
posted on 21/3/18 at 08:18 PM Reply With Quote
Mike
edit sp
Just so happens I know about stuff like that, I have been known to repair the odd 20 or 30 alternators and associated stuff a week lol
daviep
posted on 21/3/18 at 08:41 PM Reply With Quote
I'm not doubting you, I wanted to know the actual technical reason to increase my understanding.
Davie
gremlin1234
posted on 21/3/18 at 09:51 PM Reply With Quote
Davie
the alternator requires a reasonably small current though the circuit.
a 2.4W 12V bulb is 200mA
led, with is resistor < 10mA
in series these two would only pass the led current. (actually a tiny fraction less, but negligibly so ) ~5mA
in parallel, the current would be the two added together ~ 205mA
daviep
posted on 21/3/18 at 10:47 PM Reply With Quote
Thanks, that makes perfect sense I was having a complete brain fart, obviously the resistor in series reduces the current when in fact we are trying to increase it.
Much apppreciated
Davie
