Author: Subject: MX-5 NB front uprights & upper wishbones
PorkChop
posted on 20/3/18 at 07:35 PM Reply With Quote
After leaving my build in the garage for over 18 months, I'm trying to get my backside in gear and make some more progress on it
Currently looking at the front suspension, where I'm using MX-5 NB uprights and original SSC spec wishbones (M14 x 1.5 threaded inserts).
I'm trying to source a suitable ball joint to connect the upper wishbone to the upright. If I was using a NA upright, I could use the BMW 7 series track rod end that SSC suggested.
However, the upper mounting point on a NB is significantly thicker than an on the NA upright, meaning that the BMW TRE is really too short (I've mocked it up on the car as I already have the BMW TREs).
Has anyone come across an alternative ball joint that will fit the NB upright taper and have a M14 x 1.5 RH thread?
Ta.
