Author: Subject: Crimp terminals for Sierra indicator connectors
gingerprince
posted on 27/3/18 at 12:19 PM Reply With Quote
Hi
Does anyone know the name and availability of the round (3mm ID) female terminals that are in the Sierra stork switch gear? Need to replace some that have had the wires cut short. On the right in this picture: -
Terminals
Terminals
I thought Molex hard drive power terminals might work like these but they're only 2.36mm. I've done countless googles with the terms crimp, terminal, female, round, socket, 3mm and struggling to find an obvious match - hoping someone's already been to the trouble of identifying
posted on 27/3/18 at 01:29 PM Reply With Quote
Can't help with a source or even P/Ns.
You may be better looking for some ready assembled connectors with longer wires to terminate.
posted on 27/3/18 at 02:27 PM Reply With Quote
That's what I did - got a connector with a chopped-off bit of loom attached, and pieced out each wire using solder and shrink-wrap sleeving.
theconrodkid
posted on 27/3/18 at 03:22 PM Reply With Quote
how many you need, i have 31 here, the male measures 3.02mm
who cares who wins
pass the pork pies
L1berator
posted on 27/3/18 at 06:21 PM Reply With Quote
Sierra Terminals
Durite 3mm female socket, part number 0-005-14
http://autoelectricalsuperstore.co.uk/index.php?route=product/product&product_id=575
Regards,
Peter
posted on 28/3/18 at 08:23 AM Reply With Quote
Regards,
Peter
Good info!
Do you need a fancy crimp tool to use them (or can they be soldered to the wires)?
gingerprince
posted on 28/3/18 at 10:26 AM Reply With Quote
Thanks all.
If you have some going spare that would be appreciated - I'll PM you.
Regards,
Peter
Perfect - thanks! Looks like they're also available on ebay in smaller quantities for about 4 quid for 10 - linky
I bought a ratchet non-insulated crimp tool, chinese thing, was a bit crap really. Now use one of these, and it's seems to create much better crimps - linky dink
