Author: Subject: Alternative to Sierra Calliper to enable 13" Wheel Fitment
sammini7
Contributor
Posts 28
Registered 14/8/17
Member Is Offline
Photo Archive Go!
Building: GTS Panther (Honda K20A + RX8 6 Speed G.Box)
posted on 31/3/18 at 12:58 PM Reply With Quote
Happy Easter People!!
I wonder if anyone could help me my car is sierra based car, currently being built. I am looking to keep 13" wheels, what are my options regarding rear callipers and handbrake mechanism?
Kind Regards
JMW
posted on 31/3/18 at 02:20 PM Reply With Quote
where are you?
Daf
posted on 31/3/18 at 02:44 PM Reply With Quote
What rear upright are you using? I designed some brackets to hold mx5 rear calipers to the sierra hubs and using fiesta mk1 front disks. I had a bunch of them laser cut and I may have a pair left, but it depends on the design of the rear upright.
starterman
posted on 31/3/18 at 02:54 PM Reply With Quote
I have the same type of issue and I'm using Tiger rear uprights.
Mike
CosKev3
posted on 31/3/18 at 04:53 PM Reply With Quote
I've fitted hi-spec two pot rear calipers onto the Sierra upright and disc and they fit inside my comp CXR's which are 13x6 ET25.
Pretty sure there are a lot of 13 inch wheels you will struggle with for brake clearance, but I know both TD pro-race 1.2 and comp CXR's have good brake clearance as they are a motorsport wheel
johnH20
posted on 31/3/18 at 07:54 PM Reply With Quote
I use Sierra rear calipers with 240 mm discs inside CRX wheels no problem. Critical clearance is handbrake lever on rim.
jelly head
posted on 1/4/18 at 07:40 AM Reply With Quote
This: http://www.locostbuilders.co.uk/viewthread.php?tid=133728
