Author: Subject: HELP rear lower wishbone identification
Its something
posted on 9/4/18 at 06:46 PM Reply With Quote
Evening guys
Bought what was meant to be an MK Indy, but upon buying semi adjustable rear lower wishbones to find they are massively incorrect.
if anyone could help identify the original arms would be a great help as I'm struggling to find any manufactures specs online.
Thanks in advance
[img]http:// Description
[/img]
[/img]
[/img]
[/img]
[/img]
[/img]
[Edited on 10/4/18 by Its something]
ReMan
posted on 10/4/18 at 06:44 AM Reply With Quote
Welcome.
Perhaps you should post a picture of the chassis if ther is som uncertainty of “supposed to be” an MK CHASSIS.
Many unknown cars/ chassis are advertised as MK!
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 10/4/18 at 07:56 AM Reply With Quote
Its something - the images don't work in your post so I can't see I'm afraid. Having built an MK Indy a few years back I'm familiar with that chassis and wishbones so may be able to help identify if that's what you have.
Its something
posted on 10/4/18 at 07:56 PM Reply With Quote
Thanks Reman an Nick205 wasn't sure if they worked or not. Have now updated them.
i suspect if it is an MK its an early chassis.
posted on 10/4/18 at 07:59 PM Reply With Quote
My MK Indy was 2003/4 and didn't look like that. Certainly my rear wishbones were different.
Daf
posted on 10/4/18 at 08:55 PM Reply With Quote
They look similar to some luego ones I bought to modify, think I still have them somewhere so if you measure them up in could check for you.
ReMan
posted on 10/4/18 at 09:02 PM Reply With Quote
I'm still trying to convince myself it is MK thougthere a few bits (modifications exception) that i'm not sure on.
Whats happening with the diff? :-)
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
alfas
posted on 10/4/18 at 09:25 PM Reply With Quote
on 1st view i thought: thats not an MK
40inches
posted on 10/4/18 at 09:54 PM Reply With Quote
Nothing like my 2000 chassis. It does look like a Stewart Taylor in some respects?
ReMan
posted on 10/4/18 at 09:56 PM Reply With Quote
Those rear hub carriers are distinctive if not custom?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
MikeR
posted on 10/4/18 at 11:05 PM Reply With Quote
Diff mount looks very Haynes roadster.
Can you post a picture of the front chassis up to the where your feet go and confirm it's year of registration.
Suspect it's a chassis that started as one thing and got modified, perhaps by adding irs from the Haynes roadster. I guess measurements of the wishbones may help price this theory.
MikeR
posted on 10/4/18 at 11:09 PM Reply With Quote
On phone hence difficultly viewing.
Front looks like a book locost. Mk did make these originally but with a live or de-dion rear.
Start Taylor / aries did book loousts but with narrowed it's rears. So can you measure your drive shafts or take a picture of your rear wheel arch. Stuart Taylor arches look different to mk.
Mr Whippy
posted on 11/4/18 at 06:01 AM Reply With Quote
I had an MK indi and it literally bore no resemblance to what I see below -
[/img]
I have no idea what you have...
ReMan
posted on 11/4/18 at 06:31 AM Reply With Quote
I’ve still got one
Details I thought were never MK are hub carriers, squared off wishbone mounts, that double tube seat let top mount, the headlamp brackets and the difff mount. Any of which could have been modified over the years it’s still difficult to tell from some of the photos
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Myke 2463
posted on 11/4/18 at 08:30 AM Reply With Quote
Front looks very close to GTS no idea on rear.
Be Lucky Mike.
Mr Whippy
posted on 11/4/18 at 11:16 AM Reply With Quote
Originally posted by ReMan
I’ve still got one
Whole frame round the diff is totally different as are the diagonals, it even has extra deep chassis rails in the back... not an MK
DavidW
posted on 11/4/18 at 03:03 PM Reply With Quote
That doesn't look like my Indy chassis I'm afraid.
Where did you buy the wishbones from? I'd quite like a set of those.
gremlin1234
posted on 11/4/18 at 03:05 PM Reply With Quote
what does the plate attached to chassis in your third pic say?
highlighted below, on the left of the photo
jps
posted on 11/4/18 at 03:15 PM Reply With Quote
The 'book' design is for the diff brackets to bolt on - those looked welded in place to me? But yes, it does look a bit like my Haynes back end... Those wishbones though - not like the 'book' Haynes ones...
Its something
posted on 14/4/18 at 12:54 PM Reply With Quote
Thanks guys for all your input, have come to conclusion its a factory built locost chassis but by whom probably never to know.
DavidW the new ones are from MK sports cars which they now have back in stock .
As they took them back and are modifying the original ones.
Reman diff inspection to confirm ratio, which is next going to try find a ford 7.5 diff 3.64 ratio which could prove difficult.
unfortunately car isn't road registered and chassis plate is meaningless I believe.
[/img]
[Edited on 14/4/18 by Its something]
