Author: Subject: Fuel System - screwed sealing joints?
DavidW
posted on 17/4/18 at 09:09 AM Reply With Quote
I've decided to take my Indy racing in Mag 7s so am working through the regs.
The MSA Blue book on fuel lines states:
5.13.2. They may only be joined by screwed sealing joints or vehicle manufacturers approved joint.
Does anyone know what this actually means?
Will my rubber fuel hoses with fuel pipe clips pass scrutineering? They have a screw?
MikeR
Contributor
Posts 8600
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 17/4/18 at 09:39 AM Reply With Quote
MK manufactured it, what do they say / fit?
minitici
posted on 17/4/18 at 06:36 PM Reply With Quote
The devil is in the detail of the wording!
"joined" implies two lines joined.
For a line, in one piece, "terminating" at a filter/pump/tank/carb/regulator/fuel rail - I would not consider this a "join" and the usual hose clamps would be perfectly acceptable.
