Author: Subject: MK Indy
duncanjduncan
posted on 21/4/18 at 07:13 PM Reply With Quote
MK Indy
Hi all,
New to the forum; I've got a significant birthday at the end of the year and fancy building something. I've always had bikes so fancy a BEC and like the look of the MK Indys. Before I take the plunge I want to be sure this is something I can live with. So...
I'm looking to buy a smart MK Indy – road legal, bike engined with a full roll cage. Up to £7k? And ideally based London/South East.
Cheers all
D
[Edited on 21/4/18 by duncanjduncan]
nero1701
posted on 21/4/18 at 07:25 PM Reply With Quote
Ive got this lot up for sale soon..
I'm located in Kent..20 miles away from se London
I've pm'd you my number
Gbs zero chassis powder coated
Gbs zero rear differential 3.92(new)
Gbs zero prop(new)
Gbs zero handbrake(new)
Gbs zero handbrake cables(new)
Gbs zero driveshafts(new)
Gbs zero rear disks and Calipers(new)
Gbs zero steering rack(new)
Gbs zero rack fitting kit (new)
Sierra steering column with steering wheel and switch gear
Steering column extender bar.
Gbs zero body panels in aluminium (new)
Gbs zero grp panels in brgreen (new)
Gbs zero rear diffuser (new)
Type 9 gearbox and bell housing duty new gasket kit
2l Ford silvertop zetec with fast road cam and ported and polished head
Gbs zeroSpigot bearing for rwd set up(new)
R1 carbs and inlet manifold for zetec engine (put through the ultrasonic cleaner)
Cvh sump and pick up to suit zetec silvertop
Gbs zero lightened flywheel (new)
Gbs zero rwd clutch kit (clutch, rwd release bearing, pressure plate) (new)
Gbs zero Zetec engine mount set(new)
Sierra front uprights including front brake calipers.
Couple tubes adhesive
Koso Clocks Rx2n 9k and fuel tank adaptor (new)
CBS complete wiring fuse box(new)
Brake pipe
Brake connectors
P clips
In my opinion, I have not scrimped a single penny on the build so far. 95% of thenparts have not been fitted as I’ve been unable to be in the garage.
I’m sure there’s a few things I have forgot but it’s mostly there in the list.
ReMan
posted on 22/4/18 at 08:26 AM Reply With Quote
That should be doable, but you may have to accept that you travel a bit further to see them
Strongly suggest you get yoursef to Stoneleigh show next month if your doubting whether you can live with one, (which bit are you doubting the BEC bit?)
Just make sure its properly registered if you find one you like
[Edited on 22/4/18 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
duncanjduncan
posted on 22/4/18 at 09:59 AM Reply With Quote
Thanks for the responses. I'm happy with a BEC although would also consider a car engine, it's more the 'faff' factor that's making me nervous. As you note, there is the issue of navigating the paperwork/registration not to mention the build itself.
I've only ever owned cars and bikes that are basically perfect - with dealer warranties and servicing etc. So I want to dip my toe in the water first.
ReMan
posted on 22/4/18 at 10:13 AM Reply With Quote
There shouldn't be any faff any more than any other vehicle.
I got the impression you wanted to buy an OTR car not build one?
It was just a caution that if you buy a built car, that it is correctly described on the log book.
Stoneleigh usually has a selection of cars for sale too.
A well built car or BEC should not give you any more problems other than servicing, but if you are not spanner happy, then you probably want to get a bit of advice as to who might look after that aspect for you, locally?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
duncanjduncan
posted on 22/4/18 at 10:25 AM Reply With Quote
Yep, I want to buy OTR now. With a view to building one at the end of the year.
All advice VERY welcome! Will make a trip to Stoneleigh.
