Author: Subject: What size bolt is this (VERY small!)
smart51
posted on 29/4/18 at 06:23 PM Reply With Quote
I've lost a nut off my glasses and as a nut is likely to be cheaper than a new pair, I'll fix them. The trouble is, I'm not that familiar with tiny thread sizes. The bold is 1.31mm measured across the thread. What size is it? M1.6 or could it be an imperial size?
40inches
posted on 29/4/18 at 06:32 PM Reply With Quote
Take them to your opticians, they replaced a screw on mine for free
smart51
posted on 29/4/18 at 06:49 PM Reply With Quote
They are off the shelf reading glasses, not prescription lenses. I doubt they'd have spares. Nice idea though.
BigFaceDave
posted on 29/4/18 at 07:12 PM Reply With Quote
Can you improvise? I lost one of the screws out of mine and now both sides are held in with mig wire bent over top and bottom! They’ve been like that for about 2 years no problem.
Ugg10
posted on 29/4/18 at 07:26 PM Reply With Quote
Wild guess, 12BA has an od of 1.29mm so pretty close.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
SteveWalker
posted on 29/4/18 at 07:47 PM Reply With Quote
I'd still try an optician - they usually stock a variety of bits to try and repair many different types of glasses. I've never been charged for such a repair either.
jps
posted on 29/4/18 at 10:01 PM Reply With Quote
Paperclips work too in my experience...
907
posted on 30/4/18 at 06:45 AM Reply With Quote
Like others vote optician as well, unless they are from the pound shop in which case I would buy another pair and rob the screws
from them and throw the rest away.
My mate buys his glasses from the pound shop. His eyes are such that he cannot read the figures on his car speedo ,
yet can afford to go on 3 or 4 cruises a year. At this moment he's in the Norwegian Fiords, not that he can see them.
Paul G
steve m
posted on 30/4/18 at 07:17 AM Reply With Quote
One of my local poundshops had a glass's kit, screwdriver and screws kit for a quid,
but my eyesight wouldn't be up to fiddling with those tiny screws!
Now at my age even 5mm bolts are tricky
steve
[Edited on 30/4/18 by steve m]
posted on 30/4/18 at 08:19 AM Reply With Quote
I'd start with an optician as well even if they didn't supply the glasses.
SWMBO wears glasses and has had the same problem. Our local Specsavers have helped more than once for free.
coyoteboy
posted on 30/4/18 at 11:52 AM Reply With Quote
We work with M1, M1.6 and M1.7s fairly regularly, could be any of those.
There's also the japanese screw standards for watches/glasses/optics. (JCIS)
http://www.japanesescrews.com/sections/screw-threads.html
Looks like it might be a 1.4?
[Edited on 30/4/18 by coyoteboy]
ReMan
posted on 30/4/18 at 01:10 PM Reply With Quote
yes i was surprised as even a high st optician, just fixed mine for free and I was happy to pay
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jacko
posted on 30/4/18 at 04:40 PM Reply With Quote
Whats wrong with a plaster like jack of you know what show
smart51
posted on 2/5/18 at 04:51 PM Reply With Quote
Typical
I bought a repair kit off ebay for a couple of quid. Nut spinner, pair of screwdrivers and a whole set of nuts, bolts and rubbery nose pads. So I went to the garage where I'd left the glasses after threadlocking 3 of the 4 nuts, only to find the lenses smashed. One had a big chunk missing and the other was cracked. Are plastic lenses attacked by threadlock? Could I have overtightened such a small screw enough to crack several mm thick plastic?
obfripper
posted on 2/5/18 at 06:04 PM Reply With Quote
Polycarbonate is affected by direct contact and the vapours from uncured threadlock, causing cracking and embrittlement.
Other plastics and resins are also affected, there are special threadlocks for plastics.
Dave
gremlin1234
posted on 2/5/18 at 09:10 PM Reply With Quote
a lot of the very tiny screws in spectacles are locked by 'deforming' the ends on the thread, and often have a central hole that a punch may be used
