Author: Subject: Crossflow Alternator and Braket
briarswood57
posted on 6/5/18 at 01:47 PM Reply With Quote
Hi there, anyone got a cheap alternator and bracket for a 711 crossflow.
Cheers. Andrew
steve m
posted on 6/5/18 at 03:04 PM Reply With Quote
I may have a spare bottom bracket , but I don't use the top one, as it fits to the water pump, and is fragile
So I use a threaded bar off the hole in the top of the block just under the head at the front
steve
[Edited on 6/5/18 by steve m]
briarswood57
posted on 6/5/18 at 04:36 PM Reply With Quote
Hi Steve, It's the bottom bracket I am after if you can let it go - just PM me with some details and I'll send you some money and details via PayPal.
Thanks for the tip about the top bracket.
Cheers. Andrew
steve m
posted on 6/5/18 at 05:22 PM Reply With Quote
I will go and find the bracket first !
starterman
posted on 6/5/18 at 06:17 PM Reply With Quote
Which alternator is t you need?
Mike
briarswood57
posted on 7/5/18 at 08:29 AM Reply With Quote
Hi Mike - it's an LRA103 alternator.
Thanks. Andrew
steve m
posted on 7/5/18 at 11:53 AM Reply With Quote
Ive found a spare top bracket, but no lower one at the moment
steve
starterman
posted on 7/5/18 at 02:58 PM Reply With Quote
Hi Andrew,
If you want a new one at cost they are £50.28 including VAT and delivery.
Mike
Thanks. Andrew
briarswood57
posted on 10/5/18 at 09:28 PM Reply With Quote
New alternator supplied by Mike (aka starterman). First class service and packing - genuinely highly recommended so massive thanks there.
Still looking for the elusive bottom bracket if anyone has one knocking about.......
Cheers.
Andrew
jester
Contributor
Posts 169
Registered 21/5/17
Member Is Offline
Photo Archive Go!
Building: brought Jester.building a Jester own a Striker
posted on 10/5/18 at 11:08 PM Reply With Quote
Two links below
The second one states Crossflow in the main listing
https://www.ebay.co.uk/itm/mk1-2-escort-cortina-capri-711m-crossflow-alternator-bracket-3036E-S010039A/232756496922?hash=item36315e4a1a:g:nnAAAOSwAJFa 7A~G
https://www.ebay.co.uk/p/Ford-Leyland-Alternator-Adjusting-Brackets/1809810374?iid=222944970180
May be of some help
