Author: Subject: Gear Lever IVA Compliant
Stevie_P
posted on 9/5/18 at 04:13 PM Reply With Quote
Hi All
Suspect not but can you tell me if my gear lever below is IVA compliant?
If not, how have you chaps overcome these sort of issues?
Gear Lever
Gear Lever
Nickp
posted on 9/5/18 at 04:28 PM Reply With Quote
Stick a bit of rubber hose over it
Stevie_P
posted on 9/5/18 at 04:39 PM Reply With Quote
I thought it had to look permanent?
Not sure a bit of tube over would pass as that?
posted on 9/5/18 at 04:45 PM Reply With Quote
Fit a bicycle handlebar grip like this with a locking collar. Modify the locking collar to grip the gear shifter if need be.
Nickp
posted on 9/5/18 at 05:07 PM Reply With Quote
Just make sure it's a tight fit
Les1
posted on 10/5/18 at 08:27 AM Reply With Quote
I had various bits of hose and tubing
On the avon- passed ok!
Stevie_P
posted on 10/5/18 at 08:30 AM Reply With Quote
Thanks for the replies chaps.
I like the bicycle grip idea. I'm sure I can pad it out and make it fit.
