Author: Subject: wilwood M/C inlet bolt?
number-1
posted on 11/5/18 at 05:11 PM Reply With Quote
Does anyone have Wilwood master cylinders? I'm in the process of changing 2 separate brake fluid reservoirs to a single double chambered one. Ive just noticed the inlet pipe going into the Wilwoods is 9 or 10 mm ID but the new reservoirs are 7mm ID. Does anyone know if i can by a new inlet for the M/C to allow 7mm inlet pipe? Or get some inlet pipe that goes from 9mm ID to 7mm ID?
Its this part....threaded side goes into inlet on master cylinder
And here are both connected with the inlet pipe removed
[Edited on 11/5/18 by number-1]
padrc66
posted on 11/5/18 at 08:12 PM Reply With Quote
it's these parts:
http://www.rallydesign.co.uk/product_info.php?products_id=15579
but i've got 3 spare if you want them - had to change to banjos to fit under bonnet so these are left over now
number-1
posted on 11/5/18 at 08:24 PM Reply With Quote
Ahhhh top man! Is there a name for them as ive searched with no luck! I need 7/16 with 7mm into the hose. Is that what you have?
number-1
posted on 11/5/18 at 08:26 PM Reply With Quote
I need to read before i reply!..... if you U2U me your details and the price that would be great
number-1
posted on 13/5/18 at 02:47 PM Reply With Quote
The connectors are apparently called 'male BSP thread to hose tail' for anyone who ever needs to order some
number-1
posted on 14/5/18 at 04:31 PM Reply With Quote
They arrived today mate and fit a treat so thank you very much
