Author: Subject: clearout - 7 and zetec items
femster87
posted on 13/5/18 at 12:59 PM Reply With Quote
Hi all,
Since the seven is sold, I do not see myself ever building another one. So I have collected all the items I have let
1) Expansion tank - 100mm x 180mm
2) Fuel pump - brand new
3) 1.3 charade alternator - no pulley
4) 3 clutch release bearings
5) odds and sorts of silicone hoses - 32mm mostly - longs ones 22m
6) Type 9 gearbox mount
7) Zetec RWD starter motor - LR707 i believe. Worked well when removed. Engine sold
8)New copper brake line - 4.76mm x 0.71mm
9)Fuel level sender
10)Horn
11) Pair of good mirrors
12) brand new sierra caliper hand brake cable
13) laser cut battery tray - 80mm x 200mm
All above 35 collected - additional 12 if packaging and postage required
Item 2
Zetec Alternator, mounting brackets (need to find one more item so a bit of a delay) idler pullet and mounting bracket. 50 posted
Item 3
R1 power commander 3 - 85 posted
Item 4
Aluminium paddle shift - MNR's I believe might be wrong. Very well made kit - 100 posted
Item 5
Exhaust can - Not used on the road just for running engine in the workshop - 100 61mm inlet, 51 cm long can. 81cm overall lenght
[Edited on 13/5/18 by femster87]
wowblaauw
posted on 13/5/18 at 02:25 PM Reply With Quote
Hi, where about in South Yorkshire are you - have an inters in your bits and bobs
Craig
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
femster87
posted on 13/5/18 at 02:42 PM Reply With Quote
I am just outside worksop
nero1701
posted on 13/5/18 at 03:57 PM Reply With Quote
Apologies..
Ive actually got most of that lot in boxes..
My Bad.
Sorry
[Edited on 13/5/18 by nero1701]
John G
posted on 13/5/18 at 04:29 PM Reply With Quote
zetec and seven parts
Hi there, can I have the parts posted if they are still available? Regards, Jon. Will send u to u
femster87
posted on 13/5/18 at 06:05 PM Reply With Quote
Parts bits sold pending payment
owelly
posted on 13/5/18 at 11:35 PM Reply With Quote
If the sale falls through, give me a nudge. I could do with the header tank!!
http://www.ppcmag.co.uk
Stevie_P
posted on 14/5/18 at 01:13 PM Reply With Quote
Hi
Regarding the paddle shift. Does this fit the standard Sierra column.
Looks like it just clamps on and you use a standard push / pull cable?
femster87
posted on 14/5/18 at 01:39 PM Reply With Quote
Hi, this fits on the sierra column with a machined tube over the coulmn
Stevie_P
posted on 14/5/18 at 01:50 PM Reply With Quote
Thanks. I assume you haven't got the tube?
femster87
posted on 14/5/18 at 08:45 PM Reply With Quote
Sorry sold with the car
tajgreidotu
posted on 29/5/18 at 10:33 AM Reply With Quote
Got the exhaust can from femster87. I can only have positive comments.
Item arrived fast and in great condition. Really happy with the sale
ttalps2000
posted on 30/5/18 at 03:42 PM Reply With Quote
Still got the fuel pump?
femster87
posted on 30/5/18 at 08:51 PM Reply With Quote
Sold as part of first package
