Author: Subject: Wilwood caliper which way round
Ugg10
posted on 14/5/18 at 05:18 PM Reply With Quote
I bought some cheap wilwood 4 pot calipers of eBay. They are the old style billet dynamite as far as I am aware and the number 120-5321 seems to relate to ones for Clio using a 1” vented disc (any more info gratefully received including range of disc diameters they fit). I am hoping to resolve and fit to 260mm escort rs vented discs under the 14” wheels on my Anglia, will need to make up a bracket.
The question is, they have unequal pistons so which way round do they go, small piston hitting disc first or last?
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
adithorp
posted on 14/5/18 at 05:45 PM Reply With Quote
Small piston is the leading one.
http://jpsc.org.uk/forum/
Ugg10
posted on 14/5/18 at 06:14 PM Reply With Quote
Thanks. So as the wheel turns the small piston sees the disc first. Will check out fitment when I have a few minutes and check out the caliper pistons to see if they need replacing or just the seals.
Just to check, if the caliper is in front of the wheel the small piston will be at the top and if behind at the bottom.
[Edited on 14/5/18 by Ugg10]
adithorp
posted on 14/5/18 at 06:26 PM Reply With Quote
Yes that's how I understand it.
Ugg10
posted on 14/5/18 at 07:12 PM Reply With Quote
Thanks again.
