Author: Subject: What drill sharpener?
alistairolsen
posted on 16/5/18 at 10:46 AM Reply With Quote
I've got a heap of old drills which have lost their edge. Whilst not perfect for 'good' work (I keep a nice set for that), it would be nice to be able to sharpen them.
Can anyone recommend a decent drill sharpener that doesnt cost the earth?
My Build Thread
View User's Profile Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
tegwin
posted on 16/5/18 at 11:09 AM Reply With Quote
This should be all you need
https://www.machinemart.co.uk/p/cbg6rp-6in-bench-grinder/
www.verticalhorizonsmedia.tv
russbost
posted on 16/5/18 at 11:17 AM Reply With Quote
Second the above, never found a drill sharpener that was really any good, just carefully run the end against the grinder, keep cutting angle the same "as is" & ensure that the highest point is the cutting edge, you won't get it right every time, or possibly at all to start with, but once you get the knack it's easy. I've resharpened drills that have broken clean thro' & they still cut fine
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
907
posted on 16/5/18 at 11:28 AM Reply With Quote
I third the above.
The one and only member of the Suttol Owners Club. Now also the MX5 Owners Club. A few more in that one.
MikeR
posted on 16/5/18 at 12:47 PM Reply With Quote
I've got the grinder, and an attachment to help set the drill to it. Can't figure it out so bought an aldi special. Also seems ok, but only done a couple
JonBowden
posted on 16/5/18 at 05:30 PM Reply With Quote
I can fourth that, get a bench grinder then watch some you tube videos on drill sharpening.
Jon
myke pocock
posted on 16/5/18 at 07:02 PM Reply With Quote
Hate to disagree but I have done my drills the way described and it is very easy to get them slightly off center and that means it only really cuts on one edge. Also they can drift off line. Why not get none of these to attach to the grinder?
https://www.ebay.co.uk/itm/Sealey-Drill-Bit-Sharpener-Grinding-Attachment-Ref-SMS01-For-Bench-Grinder/332623640006?epid=11018235415&hash=item4d71e 9f5c6:g:m9cAAOSwNSJa1d2o
alistairolsen
posted on 17/5/18 at 12:22 PM Reply With Quote
I have a bench grinder, but not the knack for sharpening them accurately. Been doing them that way so far but wanted something guided and simple. It would appear however that they're not really all they're cracked up to be.
My Build Thread
wment
posted on 17/5/18 at 06:21 PM Reply With Quote
I have tried sharpening bits on a bench grinder but do not have the knack. I got a Drill Doctor, a bit pricey but seems to work ok. It says bits as small as 3/32" but I have not had much luck under 3/16".
wm
907
posted on 17/5/18 at 09:33 PM Reply With Quote
eBay Item
Love the typo
[Edited on 17/5/18 by 907]
