Author: Subject: Fireblade 900rr starting problems
Shiggins92
posted on 22/5/18 at 01:45 PM Reply With Quote
98 fireblade won't start in my mk indy. Can sometimes get it to start and it runs on two cylinders for a bit then three and then four. It sparks and it is getting fuel
Spark plugs are always covered in fuel and I'm not sure why?
Carbs have been replaced
Battery
Fuel pump
Starter
Stevie_P
posted on 22/5/18 at 01:54 PM Reply With Quote
Are the floats stuck in the carbs and therefore flooding the engine?
Also what fuel pump are you using? Maybe too high a pressure and pushing fuel through..
[Edited on 22/5/18 by Stevie_P]
CosKev3
posted on 22/5/18 at 02:32 PM Reply With Quote
You need to be very careful running it too rich,you will bore wash the cylinders and end up needing to rebuild the engine.
You've tried standard carbs on it?
Just wondering if someone's been fiddling and fitted the wrong size jets/or got the needles heights wrong?
ReMan
Was it ever right?
What fuel pump?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
