Author: Subject: Help with Motorhome noise
madteg
posted on 23/5/18 at 04:09 PM Reply With Quote
I have a problem with my motorhome that i am having trouble identifying.
When i take up drive from a standing start and change gear i get a single knock from front offside, sounds to me like its a C/V joint but they are only
2000 miles old. Both side C/V joints feel like they have the same amount of play in them.
Any ideas welcomed as not sure where to look now
jacko
posted on 23/5/18 at 05:16 PM Reply With Quote
engine mounts gearbox mounts
Angel Acevedo
posted on 24/5/18 at 01:33 AM Reply With Quote
Mcpherson strut?
Maybe packing up or Strut Base....
THT
posted on 24/5/18 at 08:02 AM Reply With Quote
When you say the CV joints are only 2,000 miles old do you mean the motorhome itself has only covered 2,000 miles or the CV joints were replaced 2,000 miles ago?
If the CV joints were replaced and the motorhome itself has covered higher mileage then I'd be suspecting other suspension parts or indeed engine/transmission mounts. If worn they can all move and produce a knock sound coming on/off load.
