<<  1    2  >>
Author: Subject: Starting issues....bad alternator?
lordbenny
posted on 13/6/18 at 03:10 PM Reply With Quote
I’m pretty sure the starter is fine, when it does get power to it it fires up without any issues.
posted on 13/6/18 at 05:17 PM Reply With Quote
Originally posted by starterman
That's not correct. You won't be engaging the solenoid. the starter will spin but the bendix won't be engaged in the ring gear.
Yeah maybe, I assumed the motor was inertia type, solenoid I referred to was the one that switches power to the starter.
Do we know what engine it is
lordbenny
posted on 13/6/18 at 05:41 PM Reply With Quote
Going to see if the live cable sorts it out....if not I’m paying an auto electrician £130 who said he’ll guarantee he’ll sort it!
posted on 14/6/18 at 09:41 PM Reply With Quote
Try disconnecting the positive feed to the ignition coil, if the starter then cranks the engine over faster then it may have too much ignition advance
lordbenny
posted on 15/6/18 at 08:18 AM Reply With Quote
Fitted super new live cable today.....no better.
Pressed starter button a few times and....nothing except slight dimming of ignition light.
Then the classic solenoid click....
Then it fired up but definitely only a half hearted turn over.
Turned it off and nothing again!
Calling auto electrician, he reckons that I shouldn’t be spending any more money on it and that he will sort it in his minimum 90 minute and £130 fee.
posted on 15/6/18 at 01:11 PM Reply With Quote
Voltage drop somewhere between the battery positive and the starter solonoid , dodgy ignition switch, wiring or connectors? Try checking the voltage at the solonoid feed from the starter switch when it is operated or by bridging from the main battery lead.
lordbenny
posted on 21/6/18 at 10:05 AM Reply With Quote
WOOOOOO HOOOOOO, FINALLY!!!!
Bit the bullet and got an auto electrician round.....diagnosed within 10 minutes, sorted within the hour.
Had a voltage drop between starter button and solenoid so he fitted a relay between the two and.....hey presto!
Ok, so it cost me a few quid but I don’t think I’ve ever been happier spending money on a pro to sort out a problem I don’t think I’d ever have been able to to it myself, he also put in a beefier independent fuse box for my electric fan (the old/small one was melting the plastic on the fuse after a long run).
The auto electrician in question was found on Checkatrade, he loves cars (has a mint Porsche 930 that he’s just finished restoring) and specialises in problem classics. He’s based in Crawley, Sussex/Surrey border...Phil Smith Auto Electrical 07766657180.
starterman
posted on 21/6/18 at 10:25 AM Reply With Quote
That is good news. I was sweating for a minute thinking there might have been a problem with the starter :O
Mike
lordbenny
posted on 21/6/18 at 10:48 AM Reply With Quote
Starter is perfect, thanks for your help Mike.
posted on 21/6/18 at 10:55 AM Reply With Quote
This demonstates the difference between being at the car compared to diagnosing from a distance with the full picture.
Anyway it is sorted, on to the next problem, lol.
Mr Whippy
posted on 21/6/18 at 11:55 AM Reply With Quote
glad you got it fixed but his £130 fee is still quite a bit more than the usual £10 for a half decent multi meter that could also detect that issue. Key here is to check everything no matter how insignificant
lordbenny
posted on 21/6/18 at 12:49 PM Reply With Quote
That maybe so but I wouldn’t have been able to diagnose the problem even with a multimeter. I also wouldn’t have known what type of relay to get and have been able you do it in under an hour. Sometimes it’s just worthwhile getting a pro in IMO. Best money I’ve ever spent on my car!
[Edited on 21/6/18 by lordbenny]
scudderfish
posted on 21/6/18 at 03:50 PM Reply With Quote
Quite right. Being able to recognise your own limits can lead to a much happier experience. I really made a mess of my bonnet because of my lack of talent and ended up spending more getting it done right than if I'd gone to a professional from the beginning. I can do simple electrics, I can't do bodywork.
<<  1    2  >>
