Author: Subject: Oil pressure sender question
Charlie C
posted on 18/6/18 at 09:47 AM Reply With Quote
Hi
I have a electrical oil pressure gauge and a seperate an oil pressure warning light on my Acewell digidash, can I run both of these from one oil pressure sender. Currently I have these on individual senders, but I want to make room for a oil temp sensor without having multiple tee pieces.
Charlie
gremlin1234
posted on 18/6/18 at 11:42 AM Reply With Quote
you can get combined pressure sender and switch
eg: this 'esps' unit
http://www.enovationcontrols.eu/products/electric_gauge/electric_gauge_sensors_esps_ests.htm
http://www.enovationcontrols.eu/pdf/ys6490.pdf
Charlie C
posted on 18/6/18 at 12:24 PM Reply With Quote
Thats great thanks, I'm have problems finding some where to buy one from.
ian locostzx9rc2
posted on 18/6/18 at 01:49 PM Reply With Quote
Etb instruments do a combined one give them a ring for the spec
rodgling
posted on 18/6/18 at 07:57 PM Reply With Quote
Other option is to mount one of the sensors somewhere else. The temperature sensor can go into the sump easily enough - either drill and tap or simply replace the drain plug.
