Author: Subject: Faulty oil pressure switch?
James24785
posted on 18/6/18 at 06:37 PM Reply With Quote
Trying to get to the bottom of my lack of oil warning light. I know the light works as I've tested it.
Oil pressure switch is showing a short to ground on the outer nut itself, but the terminal shows open circuit both with the engine off and the engine running.
I assume with the engine off I should be seeing a short to ground?
Are all oil pressure switches normally closed?
avagolen
posted on 18/6/18 at 06:43 PM Reply With Quote
Yes. No pressure = ground which puts the light on.
James24785
posted on 18/6/18 at 06:46 PM Reply With Quote
Thought so, cheers!
Will any eurocarparts special be ok? There's a separate sender for my oil gauge, this is literally just for the warning light (and my push button start)
avagolen
posted on 18/6/18 at 06:53 PM Reply With Quote
Yes. The thread is important. Just get one for the engine or take the old one with you.
James24785
posted on 18/6/18 at 06:55 PM Reply With Quote
Cheers mate
gremlin1234
posted on 18/6/18 at 08:48 PM Reply With Quote
there are some which ground as the pressure rises, but they are unusual.
ps don't use ptfe tape as you install it, (yea you say the body at the moment is grounded, but just a note for others ;-)
James24785
posted on 25/6/18 at 08:34 PM Reply With Quote
Just to close this off
Bought a new pressure switch from ECP for 5 quid. Fitted in 2 mins and I now have a working oil pressure light...and illuminated push button start
avagolen
posted on 25/6/18 at 09:15 PM Reply With Quote
Excellent
