New Topic New Reply
Author: Subject: What Ride Height ??
sammini7
Contributor
Posts 21
Registered 14/8/17
Member Is Offline
Photo Archive Go!
Building: GTS Panther (Honda K20A + RX8 6 Speed G.Box)
posted on 24/6/18 at 09:43 PM Reply With Quote
What Ride Height ??
I wonder if you guys can advise on the ride height your currently running on yours cars and what clearance you have on your sump.
Many Thanks
907
posted on 25/6/18 at 06:12 AM Reply With Quote
100 mm
With wife as a passenger....... 90 mm.
With my mates wife as a passenger....... 60 mm
The one and only member of the Suttol Owners Club. Now also the MX5 Owners Club. A few more in that one.
ianhurley20
posted on 25/6/18 at 07:37 AM Reply With Quote
100 mm front 125 mm rear about 85 mm under sump
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
posted on 25/6/18 at 08:20 AM Reply With Quote
This was discussed a long time back - the general consensus was that no part of the car should be lower than 100mm so that you can clear the majority of speed bumps.
This is different from the best ride height for handling, which is that the rear height should be greater than the front (as ianhurley20 has said); if you make the front higher than the rear then the handling gets VERY interesting at speed!
The older I get, the better I was...
New Topic New Reply
