Author: Subject: PINTO head question
caber
posted on 6/7/18 at 07:28 PM Reply With Quote
PINTO head question
Folks
Just a thought, I have a 1600 Pinto with some issues. I also have a Pinto 2000 head complete in good nick. What would happen if i stick the 2000 head on the 1600 engine? I know the 2000 cam is a bit of an improvement and the head should breathe better, what are the do=wnsides with this idea?
Thanks in advance
Caber
JeffHs
posted on 6/7/18 at 08:15 PM Reply With Quote
Loss of compression ratio?
snapper
posted on 6/7/18 at 09:18 PM Reply With Quote
So much less compression.
2.0L Pinto has 48cc chambers 1.6 has 38cc
However the 2.0L cam in a 1.6 Head is a very cheap improvement
I eat to survive
I drink to forget
I breath to wee my ex wife off (and now my ex partner)
jollygreengiant
posted on 6/7/18 at 10:21 PM Reply With Quote
AND it whacks the compression ratio up, even better if you get the 2.0 valves fitted into it. The 1.6GT pinto head had 2.0 valves, porting and cam as standard. edit bit - I did this back in the 90's took the CR up to about 11:1
[Edited on 6/7/18 by jollygreengiant]
View User's Profile View All Posts By User U2U Member   jollygreengiant 's Aim This User Has MSN Messenger
caber
posted on 7/7/18 at 08:00 AM Reply With Quote
Thanks for the info. So not a straight forward thing🙁 what is needed to put the 2litre valves in the 1600 head on the assumption I either have a valve problem or a cam problem? Is this a big machining job and does it require new hardened seats for unleadedness?
Thanks Caber
[Edited on 7/7/2018 by caber]
jollygreengiant
posted on 7/7/18 at 09:14 AM Reply With Quote
Thanks Caber
2.0 valves into a 1.6 (std head) will require new valve seats and porting (head off & while off inspect bottom end probably best to fit new bearings on crank while your at it). Unless you engine is a 1.6 Emax (longer block, 2.0 crankshaft with smaller diameter pistons and takes the SAME cambelt as a 2.0) in which case, a cam swap should be all you need. If you do a search on me then I think that this has been covered before by me .
Hope this helps to clear the muddy pinto waters a little.
mcerd1
posted on 7/7/18 at 11:17 AM Reply With Quote
Can't think of a better time to fit hardened seats if you we're going to do loads of work anyway...
Btw if your thinking about any machining then I've got a couple of 2.0 blocks that you could have (but they'd need a full rework)
Dick
posted on 7/7/18 at 11:38 AM Reply With Quote
Skim the 2.0 head down
caber
posted on 7/7/18 at 11:27 PM Reply With Quote
How much would you need to take off is this practically possible?
Caber
Dick
posted on 8/7/18 at 08:47 AM Reply With Quote
You need to measure the CC of the head before you skim it. Never assume anything is as it should be .
mark chandler
posted on 8/7/18 at 12:33 PM Reply With Quote
You will be yanking off a lot of material so will have to add the cost of an adjustable cam wheel, not a bad thing anyway.
snapper
posted on 8/7/18 at 01:59 PM Reply With Quote
2.0L valves in 1.6 Head will need port throat under the valve set opening out or you’ll restrict flow and gain nothing.
Getting compression down if fitting 2.0L Head would need a mix of block decking, head skimming and gasket thickness.
By the time you have done all this fitting a 2.0L is cheaper
A 2.0l with injection head and Kent FR32 will give 130bhp plus
[Edited on 8/7/18 by snapper]
I eat to survive
I drink to forget
mcerd1
posted on 8/7/18 at 08:38 PM Reply With Quote
^^ what he said - if your even thinking about doing any of this then why stick with the 1.6
