Author: Subject: Aagghhh, what am I doing wrong!!
Markymark
posted on 19/7/18 at 06:39 PM Reply With Quote
OK guys I need your help!
So I'm fitting the wheel bearings into my Sierra rear hubs, tapped the outer races in so they sit flush on the lip, bearings greased up, seals in, push in the front flange, tap in the shaft (lobro type), tighten the nut, so far so good.
When I tighten the nut up the bearing goes pretty much solid, just about turnable by hand at 150NM, that can't be right can it? I'm sure they are supposed to be 250Nm??
What am I missing, I've stripped it down twice, inspected and refitted, I can't see anything wrong, they just seem far too tight!
Any help is as always greatly appreciated
Mark
adithorp
posted on 19/7/18 at 07:09 PM Reply With Quote
The outer races should go in as far as possible not just flush.
http://jpsc.org.uk/forum/
ReMan
posted on 19/7/18 at 07:14 PM Reply With Quote
Wot he said.."...
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
posted on 19/7/18 at 07:54 PM Reply With Quote
As already stated you need to fit the bearings into the housing as far as they will go, even then you may find they are initially tight after tightening the hub nut
Markymark
posted on 19/7/18 at 09:29 PM Reply With Quote
Thanks for the replies, sorry I meant, right down as far as they would go until they are hard against the central ridge, I didn't make that very clear
So keep the answers coming
Mark
hkp57
posted on 20/7/18 at 03:05 AM Reply With Quote
I had same issue they feel really tight but trust the numbers, build it up set the torque to 310 to 350 Nm or 229 to 250 lbf / ft
They will feel tight as hell by hand but by the time you have a wheel on and they free off quick.
Failure to achieve these torque figures will result in the nut backing off, I had it happen on track and it pushed the pads back in resulting in no brakes at the next big stop.
[Edited on 20/7/18 by hkp57]
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
CosKev3
posted on 20/7/18 at 07:03 AM Reply With Quote
As above,They are really tight to turn with new bearings trying to turn the hub by hand.
Once a wheel is on,or use a bar between the studs they will turn
Markymark
posted on 20/7/18 at 10:23 AM Reply With Quote
Thanks guys
So it turns out I'm not doing anything wrong!!!
I just can't believe how tight they are.
Mark
jps
posted on 20/7/18 at 11:10 AM Reply With Quote
Mark
How did you drift them in? I have a packet of new bearings ready to fit once i've given the carriers a final coat of paint. Was considering taking them down to the local garage to fit though.
Markymark
posted on 20/7/18 at 12:10 PM Reply With Quote
Found a thick flat disc of metal and tapped that to start with then used a punch to tap them right home. You just need something to start them off squarely. Hope that helps.
Mark
