Author: Subject: Prop shaft angle cbr1000xx
Blister
posted on 21/7/18 at 06:49 PM Reply With Quote
I'm currently trying to work out if my engine conversion is possible
I have a suzuki cappuccino and a honda super blackbird engine in my garage at the moment. Today I tried to see if it would fit into the engine bay.... well it doesn't
The more worrying thing in my mind at the moment is that the prop adaptor on my engine is so far over to the driver side in relation to the original prop shaft which is central in the tunnel
I intend to use a reverse box however does this look like it won't be possible?
Engines sump is parallel with the floor
Blister
posted on 21/7/18 at 06:53 PM Reply With Quote
[Edited on 21/7/18 by Blister]
Blister
posted on 21/7/18 at 06:55 PM Reply With Quote
If I cut the bulkhead I can get the engine alot lower and further back however it will make the prop adaptor even move over to drivers side
russbost
posted on 22/7/18 at 04:30 PM Reply With Quote
Would it be feasible to turn the engine at an angle, so the prop back to the reverse box runs at an angle thro' the tunnel, I believe U/J's can cope with angles of around 20/25 degrees? Maybe even put the reverse box at a slight angle too reducing the angle on the front half of the prop & introducing a small angle on the rear half?
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
Blister
posted on 22/7/18 at 06:18 PM Reply With Quote
Hmm that's an idea didn't think of that. So run the engine so the prop shaft adaptor is pointing more towards the rear passenger tyre slightly and do the same for the reverse box.
I also had an idea possible rotating the engine anti clockwise so the cam cover is slightly more flat with the underside of the bonnet however the carbs float chambers would be parallel with the ground and the sump no longer would be
Blister
posted on 23/7/18 at 08:29 PM Reply With Quote
Managed to get the engine in alot lower and further back there isn't much room to get the engine over or twist it really due to steering rack in the way
https://ibb.co/mCYQ8d
[Edited on 23/7/18 by Blister]
Blister
posted on 23/7/18 at 08:31 PM Reply With Quote
jossey
posted on 24/7/18 at 12:39 AM Reply With Quote
I had one fitted by mac1 at 25 degrees and it knocked badly at low speed. It was a modified Sierra prop. So I got one remade.
The guys who made my prop shaft said no more than 15 percent at each joint. I turned my blade engine slightly toward the tunnel and run 13 degrees and was fine.
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
Blister
posted on 24/7/18 at 09:05 AM Reply With Quote
Don't have any room to rotate it as the chassis rail is in the way could I possibly convert this Super blackbird engine to cable clutch??
CosKev3
posted on 24/7/18 at 09:32 AM Reply With Quote
I think you will need to cut the chassis out and remake it once the engine and prop are mounted
feckn7
posted on 24/7/18 at 08:43 PM Reply With Quote
I run a 2 piece drive shaft with a centre CV joint (Holden commodore - opel?)
The UJ's run almost straight with all the angles taken up by the CV joint.
I was told by the engineer who made my shaft that the holden CV can take 300+bhp at all sorts of angles
The Blackbird clutch slave cylinder gets in the way of the drive shaft - I made an adaptor plate so that I could rotate the slave to get the fluid connectors/bleed nipple out of the way - had to make the pushrod a bit longer as well.
I am using a cable clutch (hand operated) but that then operates an hydraulic master cylinder to work with the honda slave.
jossey
posted on 24/7/18 at 09:36 PM Reply With Quote
As mentioned cut the chassis rail out once in place. I made a removable BEC mount for mine which unbolted and lifted out. Also had to remove part of the lower straight rail and move slightly.
Can you show us pics. Or a drawing of it from plan view.
There will be a way I'm sure of it.
My tiger build took 4 mocked up options before I got it right.
David Johnson
Blister
posted on 21/9/18 at 07:23 PM Reply With Quote
Bulkhead has now been cut and engine is much further back and lower.
Subframe will need notching slightly I believe or slightly raise the engine up
https://pasteboard.co/HEXj7tS.jpg
https://cdn.pbrd.co/images/HEXj7tS.jpg
Space for headers
https://imgur.com/a/Ks5mX03
https://ibb.co/bU3rxK
Sump is a shallow baffled sump which is flat however it isn't perfectmy flat with the ground is this a problem?
https://ibb.co/bsFRWe
[Edited on 21/9/18 by Blister]
