Author: Subject: inlet manifold off
craigdiver
posted on 29/7/18 at 09:30 AM Reply With Quote
inlet manifold off
Hi all, still chasing air leaks and decided to bite the bullet and remove the inlet manifold, what are the smaller ports below the main ports for?
Found a couple of hoses that seemed ok but fell apart when touched - hope that was the problem. New CCV and hose set ordered. Also gave me the opportunity to remove both purge valve and secondary air pump valve (and blanked off).
[Edited on 29/7/18 by craigdiver]
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
