Author: Subject: Where to buy push pull gear selector cable
dunk3
posted on 30/7/18 at 02:09 PM Reply With Quote
Where do you all buy your gear selector push and pull cables from.
[Edited on 30/7/18 by dunk3]
posted on 30/7/18 at 02:46 PM Reply With Quote
Is this for a specific gearbox and do you already have gear lever?
richwill
posted on 30/7/18 at 02:55 PM Reply With Quote
I used cable tec for my gear cable. Great service.
www.cable-tec.co.uk
dunk3
posted on 30/7/18 at 03:09 PM Reply With Quote
It's just for a standard gearbox on a suzuki gsxr, and no I haven't got the gearstick yet
INDY BIRD
posted on 31/7/18 at 06:31 AM Reply With Quote
http://www.mksportscars.com/push-pull-gear-cable-1-7m-long.html?SID=e92gr6u93bgjl51p2gvkqmkja0
russbost
posted on 31/7/18 at 07:28 AM Reply With Quote
Just use a standard "Morse" or "Teleflex" cable, available in all sorts of lengths & cost around £20 or so. The threads are imperial, but are so close to a metric thread (M5 IIRC) you can use metric rose joints on the ends, or just make up a bespoke adapter if required
bonzoronnie
posted on 31/7/18 at 07:32 AM Reply With Quote
The picture on the MK link appears to be a standard morse cable used in boats
Do a search for " Teleflex 33c morse cable "
A 4ft cable can be had for less than £20
Edit
Beat me to it Russ
[Edited on 31/7/18 by bonzoronnie]
dunk3
posted on 31/7/18 at 07:58 AM Reply With Quote
Thanks guys will check them out .
russbost
posted on 31/7/18 at 08:04 AM Reply With Quote
Yeah, I thought the MK one looked just like a normal Morse cable, but it says "M6 thread" which somewhat confused me as I've never seen a metric Morse cable, tho' not to say they don't exist
dunk3
posted on 31/7/18 at 08:24 AM Reply With Quote
Just looked at the morse cables but they don't have any thread and nuts on them higher up the cable were you would feed it through the hole in the chassis to attach them to the chassis.
russbost
posted on 31/7/18 at 08:38 AM Reply With Quote
They are held in place by a circlip or similar, I slid mine thro' a length of tube with a plate welded to the end, then drilled & slotted a small piece of 3mm steel plate to slide into the slot on the cable end, bolt in place & cable is secure, your adjustment is then on the cable ends
bonzoronnie
posted on 31/7/18 at 08:53 AM Reply With Quote
In marine use these cables are typically clamped in place.
Head to ASAP supplies
Search for 33c morse cables
They have a large range of cable clamps & end fittings
ASAP's morse cables can be had cheaper elsewhere
For example marinescene.co.uk
Edit
Ebay item no: 302018406590 is a basic type cable clamp
dunk3
posted on 31/7/18 at 11:53 AM Reply With Quote
Thanks for the links will also check them out .
PAUL FISHER
posted on 1/8/18 at 07:20 PM Reply With Quote
Mk did use cable Tec for there cables a couple of years ago for there shifter's.
http://www.cable-tec.co.uk
