Author: Subject: Wanted: Tillett B6 or equivaent
Trigger1
posted on 9/8/18 at 06:25 PM Reply With Quote
I'm looking for a Tillett B6 or equivalent seat if anyone has or knows of one for sale?
matt5964
posted on 9/8/18 at 08:04 PM Reply With Quote
On the bay
263861035653
123289207122
123261306030
323357735883
253759755710
263822617807
323375220796
323385496919
142895182188
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
Trigger1
posted on 10/8/18 at 07:18 PM Reply With Quote
Originally posted by matt5964
On the bay
263861035653
123289207122
123261306030
323357735883
253759755710
263822617807
323375220796
323385496919
142895182188
Thanks Matt, unfortunately it needs to have the bulge in the bottom and other than the first one (which would have been perfect but has been removed!!) and the second which is too expensive for me (£500) the others are no good
[Edited on 10/8/18 by Trigger1]
matt5964
posted on 10/8/18 at 08:34 PM Reply With Quote
No worry’s
Why does it need to have the bulge in the bottom?
Trigger1
posted on 10/8/18 at 09:16 PM Reply With Quote
No worry’s
Because I am on the tall side and I need to be as low as possible.
matt5964
posted on 10/8/18 at 10:09 PM Reply With Quote
Ah ok, with the correct brackets most of the ones I posted will fit with the seat base on your floor
The below has a similar bulge and cheap
323385496919
I doubt you’ll get a Tillett for much less than £450-500, worth every penny as they are so much stronger and finished better than the rest
Trigger1
posted on 12/8/18 at 06:38 PM Reply With Quote
323385496919
Thanks matt They are about £550 new now so hoping I can get one a bit cheaper.
matt5964
posted on 12/8/18 at 06:44 PM Reply With Quote
No worry’s
550 new is a good price thought they were just under 600 when I was looking, wend for b5’s in the end
Trigger1
posted on 15/8/18 at 05:11 PM Reply With Quote
No worry’s
I had B5's before but prefer the higher sides of the B6 for track use.
matt5964
posted on 16/8/18 at 08:50 PM Reply With Quote
Just see thease two pop up for sale, made by Tillett virtually same as B6
142904653656
142904645796
