Author: Subject: Multiple For Sale Items
nero1701
posted on 19/8/18 at 10:51 AM Reply With Quote
Sorry, Just re-read rules regarding posting..
GOODRIDGE Braided brake pipe set of 4 for ZERO
Unused and still wrapped
£40 Delivered
Link
Zero Hand Brake Assembly Kit (Disc)
Fitted but never used
£60 Delivered
Link
Type 9 gearbox and bell housing with gasket kitwith release arm
Bell housing currently separated but can reattach if required.
£225 Collected.
How To Build & Power Tune Weber & Dellorto DCOE, DCO/SP & DHLA Carburettors
Link
Thumbed through a couple of times but never seen a garage.
£12 Posted
Remote Brake Reservoir Kit
Brand New, Never Fitted
£75 Posted
Link
Twin Cam Engine Mount Set Powder Coated
Still in the bag,Never Fitted
£85 Posted
Link
Lightened Flywheel Clutch Type 9 Zetec Kit
Boxed and Never Used
£375 Posted
Link
Type 9 Prop Shaft
£140 Posted
Link
Steering Rack Extensions Ford (pair)
Brand new and never fitted
£25 Posted
Link
Wilwood brake kit Ford Sierra 2wd based kit car 260x10mm Powerlite 4 pot caliper SOLD
Link
£275 + P&P
Koso RX2N
10k Revs version
Brand new and in box with all brackets, wiring and sensors also included is a fuel level adjustable resistor box to match to your fuel set up
£160 Delivered
Link
Car Builder Solution 12 Circuit Wiring Module and Carbon Effect Cover
£100 Delivered
Link
[Edited on 19/8/18 by nero1701]
Tonesta
posted on 19/8/18 at 08:52 PM Reply With Quote
Hi do you still have the prop shaft? If so can you let me know the length.
nero1701
posted on 20/8/18 at 09:55 AM Reply With Quote
Yes, I still have the Prop Shaft,
The length from the Diff flange(inclusive of the flange on the prop only) to the end of the universal joint at gearbox end is 615mm the length of the end that goes into gearbox is 105mm
Tonesta
posted on 21/8/18 at 08:15 PM Reply With Quote
Hi thanks for the details unfortunately it’s a bit shorter than mine, shame because mines got a blemish right where it runs on the seal.
nero1701
posted on 29/8/18 at 05:27 PM Reply With Quote
Bump
nero1701
posted on 4/9/18 at 07:16 PM Reply With Quote
Will start listening to sensible offers on parts
nero1701
posted on 12/10/18 at 08:15 AM Reply With Quote
Sold.
craig_thomas
posted on 14/1/19 at 08:48 PM Reply With Quote
Is the clutch and flywheel kit available??
nero1701
posted on 14/1/19 at 09:13 PM Reply With Quote
No, Sorry, as above, Sold
adam1985
posted on 14/1/19 at 10:43 PM Reply With Quote
Is the koso clock sold?
nero1701
posted on 14/1/19 at 10:52 PM Reply With Quote
Yes mate ,
Only parts left are the engine mounts and remote brake reservoir
[Edited on 14/1/19 by nero1701]
kevyo89
posted on 15/1/19 at 06:02 PM Reply With Quote
I'll take the steering rack extenders.
nero1701
posted on 15/1/19 at 06:22 PM Reply With Quote
Originally posted by nero1701
Yes mate ,
Only parts left are the engine mounts and remote brake reservoir kit
