luke2152
posted on 27/8/18 at 08:45 PM |
very off topic - house heating systems
Well it has dawned on me that I have not a clue how my heating system works and I'm sure the collective here had a pretty good knowledge. This
is kind of with a view to installing a smart phone based control system or upgrading system but mainly I just want to get to grips with what all the
components do. My hot water requirements in summer are limited to 5 min showers and washing dishes plus I spend a lot of time away from home so I
suspect I'm heating far more water than I need to.
So I'll attach photos of the components and explain what I think they do so that I can be corrected:
So a switch connected to what appears to be a timer and in turn connected to a water cylinder. This switch is turned off and I've not used it,
when turned on I hear kettle like noise leading me to assume it is an electric heating element in the cylinder that is not used but connected either
as a alternative means of heating or just because it is the old system and since upgraded. I don't know if the cylinder stores hot water when
the gas heater is doing its thing or if the gas heater is powerful enough to heat the water as it is used (I'm guessing the former).
Siemens controller and appears to be the only modern bit of the system here - it connects to the gas heater above and allows setting of the timing
when the gas heater kicks in. I assume this could be replaced with another system with simple rewiring? In the background is control for circulation
pump. Max, med and min speak for themselves but what does C1, C2, C3 refer to?
The gas heater. Glow worm 2 by name. Has a temperature control which I assume relates to the temperature the hot water comes out of the tap.
I've not adjusted it.
Thermostat I think speaks for itself. It appears to be connected to the gas heater only although the wiring is a bit complicated. I've not had
need for the central heating yet so turned down and doing nothing.
cliftyhanger
posted on 28/8/18 at 05:45 AM |
A pumped system (as opposed to a combi, which does not have a hot water tank and heats water on demand)
When the heating is on, the hot water out of the boiler will circulate around the radiators and the hot water cylinder (the cylinder has a coil of
pipe in it that the hot water goes through, which heats the water in the tank)
When the heating is off hot water from the boiler is diverted by a valve so it only goes to the hot water tank (maybe via a radiator in the bathroom,
which is quite handy for drying towels etc)
So yes, you are heating way more water than you are using. But is it worth changing things? If the boiler is OK (I have no idea on age and how long it
will last etc) it isn't worth doing anything except use the controls to heat the water for about 30 mins or so shortly before the shower.... You
don't have to heat the whole tank, the hot water takeoff is at the top.
First pic with the mechanical timer will be for the electric immersion heater in the tank. Probably 2kw electric, gas will be cheaper to use and keep
the system ticking over (good thing)
The siemens programmer you need to get the instructions and set it up for when you want the hot water on and the heating on. Then the thermostat set
for the temp you want the house at... The heating will then come on ONLY when it is programmed to do so, and will only come on if the house temp is
lower than the thermostat.
HTH
Mr Whippy
posted on 28/8/18 at 06:18 AM |
I think you'd be better off fitting an electric shower, heating a tank like that (no lagging either) is a very inefficient way of doing it. Even
a small dishwasher would be a better option, they actually use and heat very little water. If your away from the house a lot I'd be fitting foam
lagging on the pipework there in case there was a cold snap. Apart from the wire to the pump it all looks well done, I wouldn't personally
bother changing any of the equipment, certainly not some silly phone app. It looks like an older house, perhaps the money would be better spent
improving loft and cavity insulation so you use the heating system less.
motorcycle_mayhem
posted on 28/8/18 at 08:59 AM |
Your lifestyle suggests an electric shower would be a no brainer.
I've also installed an instant water heater under the kitchen sink, it's been superb for hand/dishwashing. The hot water tank is retained,
but very rarely used.
An electric towel radiator sits on the bathroom wall.
OK.. so I have no access to gas, the oil burner isn't in great shape, so point-of-use devices fit my needs perhaps more than yours.
luke2152
posted on 28/8/18 at 12:46 PM |
Good advice well presented. So if i got an electric shower heater and equivalent for the kitchen sink, i could just use the gas for central heating
and then only in winter. Makes sense. My reasoning behind wanting a phone app thing would be to turn heating back on prior to returning from a week or
two away. Perhaps just remotely operated thermostat?
cliftyhanger
posted on 28/8/18 at 01:36 PM |
I got a Hive thingy from toolstation a while ago. £50.... so seemed good value to me for those instances when you do leave the heating off when
away.
Re kitchen, tempted to say boil a kettle to wash up, save a load of wiring etc.
Electric shower, you "should" get it installed by a sparky, but not complex. Just get the correct size wiring (I would use 10mm stuff, so
you caould use a 10kw shower, but 6mm is ok for a 9.5kw one. And much easier to install should you DIY. Don't foget the correct sized MCB that
must be RCB protected....
And if away in the winter, either drain the whole system down and turn off at the main inlet (yep, including the H+C tanks) OR fit a froststat to stop
a burst pipe. A place I do a bit of work at had a neighbor go away earlier this year, I got a call asking for help as a feed to the water tank in the
loft had split, and left running for possibly 3 days. Whole house is still a wreck 6 months on. And the place I work in is just about dry enough to
repair/decorate the party wall.
