Author: Subject: Mixed tyre sizes front to back
chris_smith
posted on 31/8/18 at 12:26 PM Reply With Quote
For Iva can I have mixed tyre sizes per axle?
Ie on the front 195/55 r15
On the rear 195/50 r15
Reason being that the Speedo is reading wrong when I use the wheels that came with the donor which are fitted with tyres to large and I just so happen to have the 2 wheels with the correct size
ttalps2000
posted on 31/8/18 at 12:41 PM Reply With Quote
I would say no. They check them that they are the correct rating etc anyway and they will pick up on it. However it will depend on your inspector most likely! Call into your local IVA station and ask is the best bet, or fix the speedo issue which you will need to anyway!
Nickp
posted on 31/8/18 at 12:46 PM Reply With Quote
Why would it matter? I had 205 rears and 185 fronts for the IVA, which is quite normal.
adithorp
posted on 31/8/18 at 12:57 PM Reply With Quote
As long as the tyres are the same on the same axle then no problem. It's not uncommon to have 2 sizes but unusual to have larger on the front... but there's no rule against it.
http://jpsc.org.uk/forum/
russbost
posted on 31/8/18 at 02:36 PM Reply With Quote
^^^^^ What Adi said!
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
