New Topic New Reply
Author: Subject: MOT woes
van cleef
posted on 4/9/18 at 02:40 PM Reply With Quote
MOT woes
Me and a friend have just equired a 13 plate mac1 with a 954 fireblade engine..
The car was correctly registered but on the MOT tester is struggling to find out the emission levels itís supposed to pass on, and on the V5 it states N/A as does the paper work that came with the car....... the tester has now stated that it may not pass unless this has been sussed out.
The previous owner who built it ran it for three years and never put it through an MOT and ended up being off the road for two years.
The tester said that MAC1 might be able to shed a bit of light, but am I right that the company is no more?
Last thing is it imperative to run the engine along side a power commander as it doesnít currently have one?
joneh
posted on 4/9/18 at 02:59 PM Reply With Quote
Could the car have been SVA'd with a pre 1979 engine and therefore been sight tested only?
I'd expect you'd need to find out the age of the engine and test to these standards now. Hopefully someone will have a definitive answer for you.
posted on 4/9/18 at 03:04 PM Reply With Quote
Can Honda (or a Honda dealer) not tell you the engine age from the engine number?
CosKev3
posted on 4/9/18 at 03:08 PM Reply With Quote
When the tester puts the reg into the computer it will tell him the emissions target it needs to pass.
Think he's being an arse, find somewhere more friendly
theconrodkid
posted on 4/9/18 at 03:33 PM Reply With Quote
is it a 13 or a Q plate ?, if it,s a Q then it,s visual only, as coskev says, the computer should say the limits, go to someone who understands such cars
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
van cleef
posted on 4/9/18 at 03:45 PM Reply With Quote
Definitely a 13 plate and not a Q...we bought as it was so cheap.... normally the tester is friendly and helped me a lot with my old Toniq R.
[Edited on 4/9/18 by van cleef]
gremlin1234
posted on 4/9/18 at 03:58 PM Reply With Quote
does the paperwork that came with the car include a copy of the iva test certificate?
van cleef
posted on 4/9/18 at 04:02 PM Reply With Quote
Yes but it states N/A too.. really struggling with this
gremlin1234
posted on 4/9/18 at 04:19 PM Reply With Quote
some time ago there was a similar thread,
http://locostbuilders.co.uk/forum/47/viewthread.php?tid=211705
read obfripper's very helpful post (about the fourth one down)
which gives emissions standards codes for the iva mac certificate
CosKev3
posted on 4/9/18 at 04:22 PM Reply With Quote
Great info there
loggyboy
posted on 4/9/18 at 04:31 PM Reply With Quote
Its the revised MoT thats causing the issues
it states:
Kit cars
Kit cars and amateur built vehicles first used on or after 1 August 1998 must have either Single Vehicle Approval (SVA) or Individual Vehicle Approval (IVA).
You must test kit cars or amateur built vehicles to the limits in the vehicle's registration document (V5c). If the V5c doesn't show any limits, you must test it to the limits based on the date the vehicle was first used.
Which means you get lumped in the post 2002 emission standards. (top right)
40inches
posted on 4/9/18 at 04:50 PM Reply With Quote
it states:
Kit cars
So the Q plate smoke only no longer applies?
gremlin1234
posted on 4/9/18 at 05:05 PM Reply With Quote
for emissions; Q plate is still treated as a pre 1 August 1975
so visual only
[Edited on 4/9/18 by gremlin1234]
40inches
posted on 4/9/18 at 05:43 PM Reply With Quote
so visual only
That's what I hoped, but I can't find any reference to Q plates in the revised MOT?
obfripper
posted on 4/9/18 at 06:02 PM Reply With Quote
If your car was originally iva'd with the 954 blade engine, it will require a cat emissions test as the engine is 2002/3 and first reg is 2013.
If it had a different engine at iva, then you need to look at your iva mac certificate and find the last digit of the type code.
If this corresponds to a lesser emissions limit, then you need to get the dvla to correct your v5.
so visual only
https://www.mot-testing.service.gov.uk/documents/manuals/class3457/Introduction.html#section_6
Dave
gremlin1234
posted on 4/9/18 at 06:03 PM Reply With Quote
Originally posted by 40inchesThat's what I hoped, but I can't find any reference to Q plates in the revised MOT?
secn6b
and reiterated in secn 8.2.1.2
van cleef
posted on 4/9/18 at 06:54 PM Reply With Quote
As far as Iím aware it was registered with the 954...canít understand why there wasnít more info on the emissions.
Big thanks to the guys on here as itís put me more into the light of things than I had hoped
snapper
posted on 4/9/18 at 06:57 PM Reply With Quote
The V5 should show required emissions in a foot note bottom of the front page
Special notes 3
My second kit on a Q however does not state anywhere emmisions so the Q plate emissions reference applies
I have a copy of the MAC for the age related kit and that does not have emissions recommendation on it.
An option is to ask what similar cars with same engine and age have on them
I eat to survive
I drink to forget
I breath to wee my ex wife off (and now my ex partner)
SJ
posted on 5/9/18 at 06:53 AM Reply With Quote
Special notes 3
Just checked on my MAC and as posted earlier there is a class code, the last letter of which indicates emissions. Mine is C which is 3.5% CO/1200ppm HC. It says NA in both the CO and HC boxes though.
Slater
posted on 5/9/18 at 07:25 AM Reply With Quote
If you don't have a copy of the MAC, can you visit the SVA station that tested the car and request a copy? Surely they will have a record of it.
ken555
posted on 5/9/18 at 04:55 PM Reply With Quote
I had the same problem back in June.
The mot computer is linked to the emissions tester, and wouldn't allow a "Visual only" check.
I'm on a 1985 issued "Q" plate, eventually the tester found a way of over-riding the system, and added a comment on the test sheet.
Seemed like the system was using the above flow chart only.
New Topic New Reply
