Author: Subject: reducing camber--which effect on toe?
alfas
posted on 8/9/18 at 05:11 PM Reply With Quote
cortina uprights, escort sterring rack on a locost
which effect on toe (tracking) has a reudced camber setting?
do i get more toe-in or toe out (and consecutively need to correct it)
steve m
posted on 8/9/18 at 05:23 PM Reply With Quote
Negative camber looks like this from the front //----\\
Positive camber is \\-----//
Without adjusting the tracking, the fo0llowing will happen
Putting negative camber in, will make the steering tow out
Positive camber will make the steering toe in
alfas
posted on 8/9/18 at 06:16 PM Reply With Quote
as my offside is -2 and my nearside is -1, whereas i would favour -0,5 for a roadcar, those are good news.
means if i reduce camber to -0,5 i will get more toe-in, so when setting tracking (back) to zero the track-rod ends would screw out from the steering arms.
the reason all behind this is: at the moment there isnt any visible thread left on the steering arms, track is slightly toe-out and i would prefer it more to zero.
steve m
posted on 8/9/18 at 07:07 PM Reply With Quote
I have my road only, Locost at around .05 to 1 % neg camber, and 0% toe, all seems fine to me
If there is not enough thread to adjust, you will need some more cut/died in, or slimmer lock nuts?
I have about 15mm spare thread on both sides,
alfas
posted on 8/9/18 at 07:30 PM Reply With Quote
the lock nuts are already slim ones.... so no chance to improve anything from that direction.
lengthening the thread by cutting aditional turns is not what I prefer. this all can be solved by setting correctly the camber.
adithorp
posted on 8/9/18 at 07:44 PM Reply With Quote
It depends where your camber adjustment is done. If the adjustment is on the top wishbone then reducing neg' camber will cause more toe-in. If the adjuster is on the bottom wishbone then less neg camber will cause more toe-out.
After a bit of experimenting, I found one turn on the lower ball joint required 1/2turn on the track rod to keep the tracking the same (transit joint and escort rack).
[Edited on 8/9/18 by adithorp]
http://jpsc.org.uk/forum/
alfas
posted on 9/9/18 at 06:54 AM Reply With Quote
yep, its on upper wishbone.
meanwhile i corrected the settings.....camber -0,7 on both sides and traclking set to 0
problem sorted.
[Edited on 9/9/18 by alfas]
