Author: Subject: Sierra ignition barrel/steering lock
JC
posted on 24/9/18 at 11:07 AM Reply With Quote
Ok....I 'may' have removed the steering wheel from my column without the key in the ignition - TBH I can't remember.
Went to refit it and the Ignition key won't turn to position 1 to release the steering lock, which is now jammed on.
Help!!!!
As I can't turn the key to position 1 I can't remove the ignition barrel....
Is there a way to sort this without drilling the pin to remove the old barrel.......and if I have to do this, what do I do to release the steering lock after this?
JC
JC
posted on 24/9/18 at 11:24 AM Reply With Quote
Ha ha - fixed.....hammer time!!!
The latch for the steering lock was jammed on the horizontal pin. A small percussion adjustment pushed it back to where it belonged, followed by levering it up with a screwdriver which freed the ignition lock.
Leaving this posted in case anyone else is as inept as me....
posted on 24/9/18 at 12:55 PM Reply With Quote
Nice work!
I've heard the hammer referred to as the universal adjuster before - must be true
