Author: Subject: iva pass trim pack.
bigwill64
posted on 6/10/18 at 04:54 AM Reply With Quote
iva pass trim pack.
10mm x 5mm rubber U channel -1.8m long (new)
10mm x 5mm rubber U channel -1.1m long (new)
7mm embossed edge trim - self gripping type with steel spine for panels - 4.6m long (new)
7mm x 7mm half round edge trim - 0.7m long (new)
M12 nut covers - 17 off (new)
M10 nut covers - 10 off (new)
M8 nut covers - 11 off (new)
20mm Rubber lined P clips - 5 off (new)
Seat belt top nut covers, have little holes drilled in side for zip ties - 4 off ( used)
4 off assorted cable/ignition lead holders on aluminium backing plates (used)
Assorted rubber cable glands ideal for covering bits of the car new
sticky pads for tie wraps new
large roll of 8/10mm safe edge moulding self gripping type. new
pair of extra long throttle cables suit rear engine or cut to suit fitted but never used on road.
im not saying this is a full kit but should cover most exposed bolts and edges.
40 ono can post at cost.
