Author: Subject: help with connector name
number-1
posted on 24/10/18 at 05:01 PM Reply With Quote
Can anyone tell me the correct name of this part? Ive searched for shell connector but cant find much info about it so presume its called something else?
N1
gaz_gaz
posted on 24/10/18 at 05:10 PM Reply With Quote
https://www.ebay.co.uk/itm/GX16-Aviation-Plug-Male-Female-Metal-Wire-Panel-Connector-2-3-4-5-6-8-9-Pin-16mm-/372040618103?var=&ul_ref=http%3A%2F%2 Frover.ebay.com%2Frover%2F1%2F710-53481-19255-0%2F1%3Futm_source%3Dtwenga%26utm_param%3DeyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwMzEyMzZjOWExNTI5MTYzYTEyYW EwNTMxOWQzY2ZkMiIsImkiOiI1OTc2NzA4ODE2ODc2NDY1MTcxIiwidHMiOjE1NDA0MDA5MjYsInYiOjMsInNvIjoxNTAwLCJjIjoxODE4Nzd9%26utm_campaign%3Dtwenga%26utm_medium%3D cpc%26ff3%3D4%26pub%3D5574631662%26toolid%3D10001%26campid%3D5338353462%26customid%3D031236c9a1529163a12aa05319d3cfd2%26mpre%3Dhttp%253A%252F%252Fwww. ebay.co.uk%252Fitm%252FGX16-Aviation-Plug-Male-Female-Metal-Wire-Panel-Connector-2-3-4-5-6-8-9-Pin-16mm-%252F372040618103%253Fvar%253D%26srcrot%3D710- 53481-19255-0%26rvr_id%3D1715768031509%26rvr_ts%3Da70cd4691660abc33073d164ffff55b4&ul_noapp=true&redirect=mobile
posted on 24/10/18 at 05:12 PM Reply With Quote
Aviation connector
[I] What use our work, Bennet, if we cannot care for those we love? .
gremlin1234
posted on 24/10/18 at 08:11 PM Reply With Quote
looks very like the connector for CB (&ham) microphones
https://www.amazon.com/PIN-PANEL-MOUNT-MICROPHONE-CONNECTOR/dp/B00H579TXU
HowardB
posted on 25/10/18 at 07:37 AM Reply With Quote
typically called 4 pin Din, also available in anything from 2 to 13 pin,... not suitable for high current or high voltage,...
Howard
gremlin1234
posted on 25/10/18 at 09:29 AM Reply With Quote
the one posted is not 4 pin din, they dont have the locking ring. also the din ones have smaller pins.
https://en.wikipedia.org/wiki/DIN_connector
posted on 25/10/18 at 09:42 AM Reply With Quote
N1
Are you wanting to source one half of it so you can connect to an existing other half you already have?
If you can't find/identify it you might be as well to replace the complete connector with something you can source.
number-1
posted on 25/10/18 at 03:37 PM Reply With Quote
Cheers for the replies lads
Its for push button gear changes. The buttons are on a steering wheel. Its going to connect to the cable so the steering wheel can be removed as needed
gremlin1234
posted on 25/10/18 at 08:51 PM Reply With Quote
in that case its very likely you could/should also use the nice coily cable from the microphones that I referred to earlier.
coyoteboy
posted on 26/10/18 at 12:29 AM Reply With Quote
https://www.amazon.co.uk/Maplin-Audio-Locking-Connector-Socket/dp/B005XK8ZDQ
Report your local potholes, it actually works!
