Author: Subject: Exhaust gas analyser CO and HC
AdrianH
posted on 30/10/18 at 03:45 PM Reply With Quote
I have had this for several years now, and used it to set the carb on my CVH engine as from about the same era, a bit like the Gunson thing but a real one, there are adjustments to zero set it before use and when it is ready it says so.
How about £50 collected from Blackburn, to heavy for me to post, it has a long'ish hose for the exhaust probe.
Cryptongas
Cryptongas
Adrian
[Edited on 30-10-18 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
westf27
posted on 30/10/18 at 04:45 PM Reply With Quote
Analyser
I would like this please but can you weigh it for me and advise.
I can get a courier to collect when I know the weight and your postcode.
Cheers steve
555
AdrianH
posted on 30/10/18 at 09:44 PM Reply With Quote
Sorry I did not see post I will weigh it tomorrow and let you know the postcode is BB3 0RS.
The only issue with not collecting is that I can not show it working and how to adjust?
Adrian
westf27
posted on 31/10/18 at 10:57 AM Reply With Quote
Perhaps when you weigh it you can advise the make and model from the id tag.Maybe i can down load usage info.
555
terryathome
posted on 31/10/18 at 12:10 PM Reply With Quote
If West27 doesn't take it give me a shout, I'm only in Burnley so would pick up.
AdrianH
posted on 31/10/18 at 07:16 PM Reply With Quote
I can not stick an image into my photo archive it seems faulty so I have posted a pic to the rear plate esewhere here is a link hope you see the image.
The unit weight is approximately 17.5 Kg plus packaging, approx size is 50 cm x 30 cm x 30 cm excluding the hose.
So I guess bigger and heavier by the time I have got it packed and boxed, need to find a big box and some bubble wrap.
Adrian
westf27
posted on 31/10/18 at 07:43 PM Reply With Quote
Thanks for your trouble but the courier cost is prohibitive.
Looks like another locoster fancies it if I didn't take it.
Regards Steve
555
terryathome
posted on 31/10/18 at 10:15 PM Reply With Quote
I'll take it please.
Pm me your address and will pick it up tomorrow night if that's ok with you.
AdrianH
posted on 1/11/18 at 06:46 AM Reply With Quote
Details passed.
