Author: Subject: LED headlights ?
steve m
posted on 8/11/18 at 06:45 PM Reply With Quote
LED headlights ?
Hi All
Ive done a LB search, but couldn't find anything related, so ...
What are the Led headlights like, as mine on the 7 are shyte ! just wondered if the led's are any better, or just a fad
steve
gremlin1234
posted on 8/11/18 at 07:01 PM Reply With Quote
led lights are good, and getting better all the time
if you want to drive over winter, then get some now, else wait 'till you are next going to drive the car in the dark.
worth looking at
https://furoreproducts.co.uk/
used to be run by russbost on here, now by his son-in-law, I think
edit, don't just get plug in led bulbs for standard h4 replacement, replace the whole uinit
[Edited on 8/11/18 by gremlin1234]
cliftyhanger
posted on 8/11/18 at 07:43 PM Reply With Quote
I have seen/tried etc (but not in my car) LED bulbs. Th ebest by far are the Philips ones, but you need a decent reflector too. And the bulbsarenot cheap at about £150/pr. However, it seems you get what you pay for.
Another, more conventional plan, is to use something like the philips extreme halogens, or the osram equivalent. I fitted some to my (Triumph) Spitfire 10 years ago, and at the same time fitted crystal headlights, and rigged up relays. The difference was amazing, and handy as I was doing a lot of 12 car rallies on Sunday evenings (better than the telly).
Until the LED bulbs come down in price to something I will pay, I will stick with the uprated halogens. But do buy branded.....
CosKev3
posted on 8/11/18 at 08:19 PM Reply With Quote
The replacement complete lights have a really good light output.
You will need a friendly MOT tester with any LED lights/bulbs retro fitted though
coyoteboy
posted on 8/11/18 at 08:26 PM Reply With Quote
I have 30£ Amazon specials. They're in my tintop and they have a great light pattern, I never get flashed and it has sharp cutoffs. Amazing light output and very happy, much happier than when I tried HIDs.
Passes MOT because they don't look too closely.
[Edited on 8/11/18 by coyoteboy]
Report your local potholes, it actually works!
steve m
posted on 8/11/18 at 10:04 PM Reply With Quote
ooopps!
Have to say sorry, as I meant the bulbs, as in H2 or H4 type and in a standard headlight housing
As my car does not lend itself to the bug eye Led style of headlight, thankfully !
I was more interested in if the BULB's were better, and give a better light pattern etc than standard bulbs
steve
steve m
ooopps!
steve
CosKev3
posted on 8/11/18 at 10:58 PM Reply With Quote
Originally posted by steve m
ooopps!
steve
Your using 5.75 inch lights with H4 bulb?
If so yeah you can get LED bulbs which give out way better light than halogens,brighter and whiter
I'll try and find the link to the ones I know work well
CosKev3
posted on 8/11/18 at 11:00 PM Reply With Quote
https://www.ebay.co.uk/itm/Nighteye-9005-9006-H4-H7-H11-Car-LED-Headlight-Kit-Bulbs-8000LM-Super-Bright/123282978932?ssPageName=STRK%3AMEBIDX%3AIT& ;var=423685829421&_trksid=p2057872.m2749.l2649
Charlie_Zetec
posted on 8/11/18 at 11:49 PM Reply With Quote
This is a big talking point with Land Rover owners, as the standard Lucas headlamp bowls on Defenders, combined with tea light candle power out-put bulbs are nigh-on useless. Having tried a selection of various configurations, I ended up with a set of Trucklite sealed-unit LED headlights, but they're not cheap at about £400+ per pair. I did dabble with LED bulbs, but found most of them to be pretty useless in comparison. The best "bang per buck" I got without spending a fortune was to replace the bowl unit itself, and invest in a set of Osram Nightbreaker bulbs. I think LED bulb replacements don't quite cut the mustard yet....
coyoteboy
posted on 8/11/18 at 11:59 PM Reply With Quote
NOVSIGHT H4 LED Headlight Bulbs Hi/Lo Beam 10000LM (2x5000LM) 60W(2x30W) 6500K Cool White - 2 Year Warranty https://www.amazon.co.uk/dp/B076ZJBS6P/ref=cm_sw_r_cp_apa_a3m5Bb44RCYZA
These work a treat in H4 reflectors.
CosKev3
posted on 9/11/18 at 08:09 AM Reply With Quote
The ones I've linked too work spot on in 5.75 inch headlights that people use on kitcars!
Bright white light with a sharp defined beam.
They don't work so well in dominators,they give out a nice bright white light but the light onto the road is still nigh on useless,just down to the size of the light unit
Mash
posted on 9/11/18 at 03:16 PM Reply With Quote
I have a set of night eyes in my Ford Transit, and they are great as you say, swapped them back out for the MOT just in case.
Had a set of of the Osram nightbreakers before that and they were very good too, and cheaper.
ste
posted on 9/11/18 at 06:55 PM Reply With Quote
Here are mine, this is on main beam, they’re great. H4 replacements off eBay.
Sidelights are the LED 501 replacements from Halfords
