Author: Subject: Brake resevoir pipe
starterman
posted on 11/11/18 at 07:15 PM Reply With Quote
Brake resevoir pipe
What pipe do most use between resevoir and master cylinders please?
Mike
SJ
posted on 12/11/18 at 10:10 AM Reply With Quote
It can be a challenge - I tried pipe what was supposed to be for brake fluid but it perished quickly. I ended up using a decent quality fabric braided fuel hose which has lasted well.
adithorp
posted on 12/11/18 at 10:33 AM Reply With Quote
I got some Fiat res' pipe for an early Panda or Uno as I remember.
http://jpsc.org.uk/forum/
posted on 12/11/18 at 10:41 AM Reply With Quote
IIRC I got mine from Think Automotive? It has been covered several times on the forum
AdamR20
posted on 12/11/18 at 11:05 AM Reply With Quote
http://www.efunda.com/designstandards/oring/oring_chemical.cfm?SM=none&SC=Brake%20Fluid#mat
https://www.google.com/search?q=epdm&ie=utf-8&oe=utf-8&client=firefox-b-ab
https://www.ebay.co.uk/itm/EPDM-Smooth-Rubber-Tubing-Coolant-Radiator-Hose-Brake-Fluid-Safe-Tube-Air-Water-/252943248471?var=
jps
posted on 13/11/18 at 12:30 PM Reply With Quote
Thanks for that - interesting as well as giving an answer!
