Author: Subject: Wanted 1.8/2.0 blacktop zetec for mock up
dbaz293672
posted on 15/11/18 at 08:53 PM Reply With Quote
Hi
Does anyone have an old 2.0 zetec block lying around that I can use for a mock up to get the engine mounts in?
I am in Stafford but work out of Wolverhampton and Preston
[Edited on 15/11/18 by dbaz293672]
kingster996
posted on 15/11/18 at 09:31 PM Reply With Quote
Bear in mind that Blacktop and Silvertop blocks are different - On a Westfield the oil filter side mount for a Blacktop will fit both but the silvertop one they originally supplied wonít fit a Blacktop. Itís all to do with where the oil filter goes.
I used to be indecisive, but now I'm not so sure
big_wasa
posted on 15/11/18 at 09:43 PM Reply With Quote
As the 1.8 is the same dimensions and much less desirable you stand a better chance. Coozer binned one the other week.
dbaz293672
posted on 15/11/18 at 10:17 PM Reply With Quote
Thanks it is the blacktop I am after and thanks yes the 1.8 or 2.0 will be fine
Tonesta
posted on 17/11/18 at 07:16 PM Reply With Quote
Iíve got an 1800 blacktop for free if you want to come and pick up asap
