Author: Subject: Injector flow rates
J666AYP
posted on 21/11/18 at 05:08 PM Reply With Quote
Injector flow rates
Hi gents,
I'm half way through the inlet system on the project and I want to upgrade the standard injectors for some stubby ones. The merc ones are expensive and known to be unreliable/leak. As usual google is throwing up loads of conflicting answers (sigh).
The engine is a 4-pot 2,300cc Supercharged. They are 197bhp std and its now going to be more like 250hp. At a later date it may be treated to a larger charger to get to the 300+hp mark. What would be my best flow rate for injectors?
Also running a adjustable regulator if that helps.
TIA
[Edited on 21/11/18 by J666AYP]
matt5964
posted on 21/11/18 at 06:19 PM Reply With Quote
I’m running Bosch 440cc injectors on a Zetec N/A putting out 221BHP and 189 ft/lb
This injector was selected and installed by emerald when they mapped the car
http://www.emeraldm3d.com/fuel/bosch-injectors-various-sizes.html
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
hughpinder
posted on 22/11/18 at 08:50 AM Reply With Quote
Here you go:
https://fuelinjectorclinic.com/flow-calculator
480 cc injectors should be good for up to 300bhp at 90% duty cycle.
coyoteboy
posted on 22/11/18 at 10:54 AM Reply With Quote
Yep, I've run 280 on 440s, pushing above 300 I switched to 540s. You want to keep your DC below 80% ideally, depending on how willing you are to rebuild engines.
J666AYP
posted on 22/11/18 at 04:33 PM Reply With Quote
Thats great, thanks gents! one more problem solved.
Jay
