Slimy38
posted on 24/11/18 at 04:43 PM |
Jacking marks for tyre fitters
I probably know the answer to this already, but does anyone put any jacking point marks on their car for the Kwik fitters of the world to know where
to jack their cars up without going through the floor?
The answer I'm expecting is 'I would never take my kit car to a tyre fitters in the first place', but just in case someone does
actually trust a tyre fitter enough to have a tyre fitted on their car I thought I'd ask.
(And I should mention that I don't even trust tyre fitters with my tintop, I'll always take loose wheels to them if possible).
ianhurley20
posted on 24/11/18 at 04:54 PM |
After my wifes Punto got a crushed sump when having her front tyres fitted (not noticed at the time I'm afraid) I would go with your last
sentence (tintop as well)
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
big_wasa
posted on 24/11/18 at 05:41 PM |
It’s not just tyres, when I took mine in for mot and the tester asked where he could jack the front to check for play in the steering.
obfripper
posted on 24/11/18 at 06:24 PM |
I quite regularly see cars that have been to "fast fit" places for tyres and were left with damaged sills, undertrays and even damaged
suspension due to a lack of observation by someone more worried about bonus than care of the vehicle they're working on.
It would be advised to find someone who is mechanically sympathetic and would bother to use jacking points to start with, but their ramp configuration
may affect what points are reachable - there should be enough alternative points on a kitcar chassis to work around this.
Dave
posted on 24/11/18 at 08:20 PM |
You can't get thicker than a Quick fit fitter!
slingshot2000
posted on 25/11/18 at 07:50 AM |
^^LIKE^^
steve m
posted on 25/11/18 at 09:13 AM |
I am in the camp, of taking the wheels off the car at home, as wouldn't trust any tyre place with my sportscar, also I doubt
there huge trolley jack would go under my car anyway
My Mondeo, I trust the tyre place that I use, so its not a problem
steve
mark chandler
posted on 25/11/18 at 09:24 AM |
High end cars with bonded aluminium floor pans get written off because of this, little Aston Martin V8V Vantages are very suceprible as the box
section gets crushed... One idot reduces your car to scrap
perksy
posted on 25/11/18 at 09:47 AM |
Couldn't get into my usual kit car friendly MOT place once and had to take it somewhere else
It was pretty obvious from the start that they hadn't tested a kit before as he wanted to test the emissions on a Q plate
I chose to stay with the car while they tested it and showed them where they could and couldn't jack it for testing
If i hadn't of stayed with it gowd knows what would have happened
rf900rush
posted on 25/11/18 at 09:59 AM |
It was no problem
Take the wheel off and take round to my local NOT quickfit.
J666AYP
posted on 25/11/18 at 12:48 PM |
After Kwick-bodge cost me a sump pan and sill repairs on my 5 series I would never go somewhere like that again.
Now I either take the wheels to them or seek out a decent family run garage.
Jay
snapper
posted on 26/11/18 at 06:48 AM |
It’s pretty simple
Get out of your car and say “I’ll show where to Jack the car, don’t lift it till I’m happy”
I eat to survive
I drink to forget
I breath to wee my ex wife off (and now my ex partner)
motorcycle_mayhem
posted on 26/11/18 at 09:20 AM |
The local tyre supermarket type place point blank refused to jack my car up. This was reassuring, it demonstrated that some outfits do worry about
jacking things up.
Car in question had long since lost any structure around the jacking points, and any structure that wasn't 30cm away from a
'sensitive' area. There absence of a rear window (the frame had corroded, it fell out) didn't inspire them with either as they went
to 'check' the rear wiper...£
I only ever take loose wheels to these type of folk, the above was an emergency pull-in, solved with a can of Tyreweld from the adjacent supermarket
since no elevation of the vehicle was possible at the tyre folk's premises.
If it was me, loose wheels only, period.
posted on 26/11/18 at 09:30 AM |
Not a fan of Kwik Fit and TBH wouldn't trust them to know where to jack a car safely or even where to find out before jacking.
I've use a local tyre fitters (Micheldever) all my driving life and never had an issue with tin tops.
I took my MK Indy there once and the operator did ask where to jack it and followed my instructions to the letter - quite happy.
Other than that I'd remove the wheels and take them to a fitters for new tyres.
Slimy38
posted on 26/11/18 at 09:36 AM |
So the general consensus is exactly as expected, basically avoid the situation in the first place!!
I'm also glad I'm not the only one to do it for the tintop too, my friends think I'm odd to go through the effort of taking loose
wheels. Especially when I'm doing a set of four and have to get the entire car off the floor.
Interesting thought about the MOT though, but I guess the average MOT guy is a bit more savvy than a tyre monkey. I do trust my local MOT tester, I
was going to book an hour of his time to go over the car once it's built (if it ever gets built!!).
Edit: Oh yeah, and avoid Kwik fit completely!! Yep, I agree with that sentiment too, loose wheels or not!
[Edited on 26/11/18 by Slimy38]
Mr Whippy
posted on 26/11/18 at 12:16 PM |
I once gave a kwik fit guy a telling off who was about to jack my Bluebird up right on the sill flange, his response was he jacks all cars up there,
what an idiot. Didn't even have a pad or anything on the jack either and as far as I'm concerned just didn't want to have to lay
down and have a look under the car. Some garages try to keep the owners out of the workshop but if you state right at the start you want to supervise
where the car is being jacked up they can either say yes or no and if no go somewhere else.
I've helped out fitters while they fit my tires and even helped during MOT's operating the controls for my kit cars so if they don't
want you there, they've probably got something to hide...
[Edited on 26/11/18 by Mr Whippy]
StrikerChris
posted on 26/11/18 at 10:37 PM |
You'd not believe how many mates I've had to bollock for standing on the exhaust as they try to get in! Seriously I'm not
fussy,stand on the side,the seat,the tunnel,forward roll over the cage, but dont stand on that red hot shiny pipe hanging off a little rubber bobbin!
steve m
posted on 26/11/18 at 11:42 PM |
Chris,
Been there ! and she had a nice pair of shoes on as well, that went all blobby over my HOT exhaust , and her heel !!!
thankfully she was pissed,
steve
jester
posted on 27/11/18 at 01:07 PM |
Lol..
I do what most people do on here.But also I get the tyre I want online not the dodgy over priced crap they try to sell you at the fitters I take two
at a time to the fanchised fitters.
Then there's tyre fitting places I have gone for a price to fit the tyres in the past. where the fitters have fitted the balance weights on the
outside of alloy wheels not the inside on other people alloys that I had seen there when waiting for a price.I just leave the your not fitting my
tyres
That shows lack of training in the first place
This is what I have been doing for years for my every day car & I will be doing the same on my kit cars when they need doing
