Author: Subject: Aluminum Coolant Reducer Tees 38mm > 15mm
StuP
posted on 12/12/18 at 03:43 PM Reply With Quote
I have a couple of aluminum reducer tees that I had custom made for me but didn't end up using. They're perfect for joining coolant or intake pipes. The main diameter is for a 38mm ID pipe and the tee-off is 15mm. 15mm Tee is barbed and the 38mm ends are swaged to help stop the pipes blowing off
Both are 100mm long
12 each delivered or 20 for the pair
[Edited on 12/12/18 by StuP]
