Author: Subject: Rear Arch Fitting - Any tips?
chrisbmxr
posted on 13/12/18 at 12:38 PM Reply With Quote
So, I am about to embark on the first winter job on my MK Indy which is replacing the standard arches with wider ones.
I have the arches now, but I wanted to see if anyone had any tips for getting the best fit?
As I didn't build the car I don't have any experience in fitting rear arches, but my plan is to remove the old arch, offer up the new arch and hold in position with G clamps and try to mark the new arch hole positions to match the current arch mounting positions?
Once fitted and I'm happy, I'll remove and transfer the lights and stone guards etc.
Thanks!!!
Slater
posted on 13/12/18 at 01:11 PM Reply With Quote
Use Tadpole trim, trap the tail in between arch and body. But make some V shaped cuts in the tail so it will fit round the curve with out getting kinked.
Make sure arches are fitted on correct sides, I've left arches seen that have been fitted on the right side, which looks a bit odd.
Fit them with nyloc nuts/bolts and penny washers to spread the load. Think I used 5 or 6 on each arch.
posted on 13/12/18 at 01:44 PM Reply With Quote
When i fitted mine i measured from the center of the wheel to the arch lip and tried to get the measurement as even as possible, nothing looks worse than a massive gap all round IMHO but make sure you have enough gap for full suspension travel
SPYDER
posted on 13/12/18 at 02:55 PM Reply With Quote
Spend an extra tenner and use stainless fittings.
posted on 13/12/18 at 03:02 PM Reply With Quote
Good advice above, tadpole trip with V cuts in the tail so it follows the curve of the arches, stainless nut/bolt/penny washer fixings so you can remove the arches in the future and ensure you get them the right way around.
Take your time as well to make sure you get a matching fit and finish across both sides!
Bluemoon
posted on 13/12/18 at 11:35 PM Reply With Quote
Stick camping Matt on inside of arch stops stones cracking glass fiber.. Used old fashioned impact adhesive..
SPYDER
posted on 14/12/18 at 08:18 PM Reply With Quote
In a similar vein to the above I sprayed the inside of my rear arches with a thick rubberised coating that also contained embedded GRP strands.
I'll try to find the name of it.
jossey
posted on 16/12/18 at 01:04 PM Reply With Quote
I attached my rear arches with plastic radiator fixing kits. So when I hit something on the track they break off and don't damage the bodywork.
The rubber trim from Woollies I put between them but the fitment on the westfield was really good so I didn't use it for that.
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
