DavidhMX5
posted on 26/12/18 at 06:35 AM |
Overall Dimensions?
Searched the book but can't find the overall width and length of a completed car.
Anyone know them or could measure their car. Accuracy not critical, within a few cm will do.
jps
posted on 26/12/18 at 08:11 AM |
It will/can depend on what bodywork /wheels you use. Chassis length plus 14" and width plus 26" is probably not far off.
DavidhMX5
posted on 26/12/18 at 08:49 AM |
Thanks.
So if I use 3.5mtr x 1.8mtr I will be well inside that. Just working out garage layout to allow work room all round.
steve m
posted on 26/12/18 at 09:23 AM |
I built my 7 in a very small single garage, so small, that even my mondeo will not even fit through the door
However, you have to have a plan, and be fairly organised, keep stuff away from the side wall, and push the car against the opposite wall to work on
either side, I still only had about 18" of room to work
Have a major de clutter first, get rid of kids bikes ladders and garden crap into a shed in the back garden or skip !
it can be done, and when the weather gets better, working outside is so much nicer
steve
voucht
posted on 26/12/18 at 09:28 AM |
Which car are you talking about?
My Haynes Roadster (Equinox Bodywork) is:
Overall Length: 3,35m
Overall Width: 1,67m
Height (roll-bar): 1,20m
555
DavidhMX5
posted on 26/12/18 at 10:34 AM |
steve
Major declutter is planned starting today for next few days. First I have to fit some boards in the loft then move a lot of non car tools in to it.
Just finished the house so these are no longer needed. Then paint floor and walls as son bought me some really nice floor paint as part of xmas
present.
Then I need to organise some upper shelving allround above head height and sort car type tools in to various tool boxes. It's mad the amount of
tools you can accumulate over the years.
Then weekend I fetch the engine back from work. I picked it up from Croyden in my car but couldn't get it out without a hoist so it had to use
the forklift at work until a host was sourced.
Most of the main construction will be done at work where I have access to very nice (Fronius) welding equipment plus a lot of machinery to make parts.
Only when I have a rolling chassis including drive train will it come home for electrics, pipe work body fitting etc.
DavidhMX5
posted on 26/12/18 at 10:35 AM |
Perfect thanks!
Yes it will be MX5 based Roadster.
steve m
posted on 26/12/18 at 10:53 AM |
While your boarding the garage loft, make sure you have good lighting in the garage, with AT LEAST TWO fluorescent's
as said my garage is SMALL, and has two fluorescent's and two 60 watt bulbs, and sometimes that's not enough
If your starting with an empty garage, I would paint the walls as well,
steve
DavidhMX5
posted on 26/12/18 at 12:09 PM |
Garage already has 3 five foot tube lights in there (single garage). Fitted when I was rebuilding a motorbike.
Ceiling and walls will be getting a good coating of white paint. Should be nice and bright in there. Also have a selection of LED lights I can use for
local spot lighting if required. I find these days I cant have too much light.
Think I might fit a radiator in there as well as some of the central heating pipes run through the garage so easy job to T in to it.
Sound bar for some music is on order.
I'm planning on a lot of hours in there.
